Yes there is, I'm sure there's other products out there but I bought some vynl/plastic in a rattle can from autozone, can't remember the name but I was impressed with how well it works..
I've had great luck with Krylon Fusion.
SEM is the way to go. It comes in spray cans, or can be custom blended to match your color exactly, even metallics. Krylon Fusion is O.K., but SEM is a lot more versatile. Use SEM cleaner (Scuff and Clean) to start with, followed by SEM vinyl/plastic prep. Then either use the Color Coat aerosols or have your color custom blended. They have standard colors for most car companies. www.vinylpro.com will match anything for you.
I was checking out the SEM products suggested, the titanium metallic looks like a match. I was trying to find out what kind of finish it left when dry but could only find info on the 3 clears they sell to go with it. Does this stuff have to be cleared? I'm shooting for a matte like finish. I was a little apprehensive about spray can stuff, but this seems to be highly recommended. Just afraid of ruining parts or making the ones I've got look worse (wife's car, part time bloomington judge
). Thanks for the great help
Haven't used the SEM brand, but you can go to your local auto paint store and they can match a single stage (no clear) paint for you. Some will mix up a pint if you talk to them real nice, but you will probably have to buy a quart. PPG has an excellent interior trim pieces paint.
Vince |
Buy a can a play with it. |
Just wanted to post an update to this ancient thread. I ended up using the SEM products to respray the interior pieces, however I opted not to use any kind of clearcoat because the finish was an exact match as well as the color. The SEM spray held up well for about a year and a half but began to spot / stain when it came in contact with any oily substance, i.e. french fries, cheeseburger grease, dash protectant. The parts are now at a point that they are going to need resprayed. I'm sure this could have been avoided had I used a protectant clearcoat when I originally painted the pieces. Just thought I'd add this for anyone looking to do the same thing.
This could have been avoided if you'd used SEM's adhesion promoter along with the dye.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
No, the leather/plastic prep is what you clean them with along with SEM Soap, adhesion promoter pulls the color into the plastic. You spray the color over the wet adhesion promoter to do that.
| Recent Interior posts with photos |
| 1966 GTO plastic trim | 69GTO | Interior | 8 | 01-06-2006 06:42 AM |
| Plastic Grill pieces | sscamaro_510 | Body - Exterior | 3 | 12-28-2004 09:00 PM |
| Vinyl and plastic trim paint ?? | mark2002 | Interior | 5 | 03-23-2004 09:02 AM |
| S-10 Headliner trim pieces?? | TurboS10 | Interior | 4 | 02-08-2004 05:54 PM |
| trim pieces | Chadwick | Body - Exterior | 1 | 12-11-2001 06:10 PM |
