ressidual valve location ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2011, 10:16 AM
I want to check the residual valves on a '67 Olds Toro. It is an all drum system, master cylinder apppears to be the same as my '69 Cutlass with drums. Problem : my 'book' say the residual valve, or check valves are located it the outlet ports of the M C . I removeed an outlet fitting ( the part the flared brake line fits over ) and nothing in there....A retired auto instructor told me it was located inside, at the end of main valve body, while my manuals say they should be under the fittings.................so where are they ???????thanks
Old 08-09-2011, 03:39 PM
Generally they are in the M/C in the area the lines connect. Sometimes they simply weren't used. You just might not have any.
Old 08-09-2011, 04:37 PM
I just now picked up new MC (exchanged) and I can feel something ''rubber ?'' under the line fittings, I assume that these are the valves, where as, the one I took off had nothing......your probabley right, thanks
Old 08-09-2011, 11:15 PM
I installed the new MC , bled the vbrakes, and road tested it. The brakes now working perfectly ! Seems as though, when 'they' rebuild these MC, some get the check valve and some don't ! I guess it's just ''buyer beware !""
Old 08-10-2011, 09:09 AM
Some of the history's best predictions were made by idiots rambling impossible results the other 99.9% of the time. I get one right every once in a while...
broken valve? valve spring is sitting off center from rocker tip. zoomo Engine 63 03-25-2011 09:37 PM
Electric Fan On/Off Control.....Location ...Location....Location Viet Nam Vette Engine 17 03-20-2008 08:39 AM
PVC valve on SBC 1970ish location question commando57 Engine 2 08-19-2005 08:36 AM
residual valve ?what location murrsue Suspension - Brakes - Steering 5 01-01-2005 07:35 PM
Can the dual coil valve springs on a BB destroy Valve guide seals Auto-Part Engine 4 11-25-2003 06:23 PM
