Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Resto tutorial on my 1958 MGA Coupe
  #122 (permalink)
Old 03-06-2013, 04:52 PM
37ford4dr's Avatar
37ford4dr 37ford4dr is online now
bobs77vet
Last journal entry: frame repair
I AM WORN OUT.... little Joe and i spent another 3 hrs tackling the mechanical items that need to be taken care to remove the engine
it helps having a worker...
we are not sure hes going to fit into when its done...
not to hard removing the master cylinder
however the car gots its pound of blood from the bolt that attaches the pedal assembly to the top bracketry....the pedals swiveled on the bushings but the bolt siezed in the steel sleeve
what a PITA....i was able to manhandle it through the opening once the ends were cut off. i could only get the bolt out the sleeve when it was in the vise.
