Resto tutorial on my 1958 MGA Coupe - Page 10 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #136 (permalink)
Old 04-04-2013, 07:04 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
45 mins tonight, laying out the panel bead and i recruited a daughter to crank the bead roller....final fitting tomorrow night. i should have just done this to begin with it looks really good.
  #137 (permalink)
Old 04-05-2013, 04:59 PM
37ford4dr's Avatar
bobs77vet
the fitting is the most important part in the back is square brace to make sure that seam was nice and flat
this is how the body is attached to the saw horses the ply wood brace just sits in side the bracketry, that way when i move the saw horses the body doesnt fall off.
the holes actually line up when the brackets are turned around
add some welding and grinding and there you go....
  #138 (permalink)
Old 04-05-2013, 05:07 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
I've been following this build quietly up until now, but I have to say that your attention to detail is staggering. What a great job you've done so far. I can't wait to see this bad boy finished.
  #139 (permalink)
Old 04-06-2013, 11:51 AM
37ford4dr's Avatar
bobs77vet
thks valkyrie5.7 its good to hear from you and that your reading it. bob
4 hours
taking care of business most small items like straighenting out the lip on the bonet opening, grinding the old bonnet rubber piece screws out and farting around with two broken fender bolts..
copper on some square tubing to act as a heat sink and a stop for the filling the gap
two low spots i cant get at because of the bracing
so i get to use my Christmas present
from eastwood it screws on to the head of the Mig torch
damn if doesnt work, i think the heat actually helps in shrinking the metal and then you use a slide hammer on it
  #140 (permalink)
Old 04-06-2013, 01:20 PM
37ford4dr's Avatar
bobs77vet
  #141 (permalink)
Old 04-06-2013, 03:58 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
talk about making a silk purse out of a pigs ear, wow the entire job.
great work continues,,,
TJ
  #142 (permalink)
Old 04-07-2013, 11:29 AM
37ford4dr's Avatar
bobs77vet
3 hrs fitting the grill.....what a PITA
chased all the nuts, this is not a tap and die it doesnt cut threads only cleans them, one of my better purchases
found a low spot, i have worked it so much there will be very minimum of filler on the nose
through the trial fit and adjustments i found a weak spot
just add some MIG steel
and 3 hrs later here you go
  #143 (permalink)
Old 04-07-2013, 01:54 PM
37ford4dr's Avatar
bobs77vet
TJ
TJ thks for the comments
  #144 (permalink)
Old 04-11-2013, 07:27 PM
37ford4dr's Avatar
bobs77vet
luckily my neighbor is a high end body man...real high end. so i use him as my sounding board....he has given me the ok to start some body filler on the front end and suggested that i use a rust converter on all the areas that i have sanded and then come back to them and sand them all again then i am good to do body filler and prime. some times its good to have another set of eyes to look at your work and give you trusted advice
so i painted the body with the stuff
  #145 (permalink)
Old 04-12-2013, 04:24 PM
37ford4dr's Avatar
bobs77vet
this stuff worked well and definitely left an anti corrosive film on the fresh metal and turned the rust black. i am not sure i would paint over the film it left on the fresh metal but the rusty parts it tuned black and you could paint over it for a chassis or something like that.
worked on the battery cover area behind the seats, some welding and wire brushed the area. i am getting to the end of the body tub!!!!
and here you can see the small black clips that hold the fabric on to the metal frame and the door seal goes over these....they have really sharp barbs on them and slice the arms really easily
  #146 (permalink)
Old 04-12-2013, 05:18 PM
I have enjoyed following your build 37 Ford. Have not contributed up till now but feel compelled to warn you about the rust converter you are using. It absolutely must be neutralized properly or your catalyzed primer or epoxy primer will not cure properly. There is good information available on the SPI forum as well as this one on the correct way to neutralize it. Do a little research before you decide to paint over it.
  #147 (permalink)
Old 04-13-2013, 04:04 PM
37ford4dr's Avatar
bobs77vet
4 hrs doing some weld repairs and wire brushing the under side of the scuttle and the top shelf in the engine compartment that was a dirty job...
  #148 (permalink)
Old 04-13-2013, 04:08 PM
37ford4dr's Avatar
bobs77vet
thks john i will be sanding it off to shiny steel and using a self etching primer, i have read about the epoxy primers and the metal prep but have found no conflicting information on the self etching primers, i will read up on it some more. its so hard not to find conflicting information, thks bob
  #149 (permalink)
Old 04-14-2013, 06:15 PM
37ford4dr's Avatar
bobs77vet
I kept working my way around the inside of the car.....wire brush, sand paper, degreaser, scotch brite pad degreaser etc etc etc. one or two weld patch panels. i painted the areas that had the signs of the weld penetration. i am thinking seriously of using panel adhesive on the rocker panels and maybe even the fender patch panels
  #150 (permalink)
Old 04-20-2013, 03:11 PM
37ford4dr's Avatar
bobs77vet
just a quick hour today sanding the inner fender area, every thing gets wiped down twice with a wax/degreaser formula before the primer
« G-body '80 Cutlass | - »
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Battery for MGA 1961_MGA Electrical 4 08-23-2013 07:57 AM
'66 Mustang Coupe Resto my66coupe Introduce Yourself 2 09-08-2010 03:33 PM
1958 Coupe Deville kjbecker Introduce Yourself 3 08-26-2010 07:38 PM
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 07:36 PM
rear end on MGA 1961_MGA Suspension - Brakes - Steering 1 09-18-2003 02:54 PM
