Resto tutorial on my 1958 MGA Coupe - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #166 (permalink)
Old 05-11-2013, 08:04 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
since the neighbor had a birthday party I decided to have quiet time in the garage.... I spent some time organizing and drilled out the last bolts, and removed the tail light plinths
and this is how you know you have done this too many times....its drilled right down the middle
  #167 (permalink)
Old 05-11-2013, 08:08 PM
life is a temporary assignment
Looking very nice so far...
  #168 (permalink)
Old 05-14-2013, 06:54 PM
37ford4dr's Avatar
bobs77vet
thks
40 minutes of sanding tonight and 2 80 grit sanding disks on the DA.....I have decided to do more effort with lower grit so i dont have to fill many sanding scratches
  #169 (permalink)
Old 05-14-2013, 07:56 PM
that fender looks to be in fairly good shape....nice job getting it down to metal.
JP
  #170 (permalink)
Old 05-15-2013, 06:51 PM
37ford4dr's Avatar
bobs77vet
thks JP there is no paint left any where on the external side when i am done sanding them, very labor intensive but bare metal is a good thing!
about 2 hrs tonight finishing the sanding on both sides and priming it.
i didnt do any of the body work to this that will come later, just wanted to get it to the point where it wouldnt flash rust on me
  #171 (permalink)
Old 05-15-2013, 07:20 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I think you have fingerprinted every inch of that car,Truley hand built ,ypur doing a great job ,keep posting photos ,
  #172 (permalink)
Old 05-17-2013, 06:17 PM
37ford4dr's Avatar
bobs77vet
7 hours today the pictures tell the story
definitely use a full face mask
life gets interesting fast when this happens
they do a great job but create a lot of heat
wire brushed the inside
left the areas that need more for later
  #173 (permalink)
Old 05-18-2013, 05:07 PM
37ford4dr's Avatar
bobs77vet
cleaned up both sides of the aluminum lip
220 grit sand paper on the DA
they look good sanded
the boot lid is under the car on the saw horse i must have forgotten to take a picture of it
  #174 (permalink)
Old 05-19-2013, 02:28 AM
Rust aside the car is surprisingly straight.
I know the front clip was toast but given it's age it isn't too bad.
You've defineitely saved a car from an ugly ending.
Well done.
  #175 (permalink)
Old 05-19-2013, 11:56 AM
37ford4dr's Avatar
bobs77vet
thks Zuffen, i eyeballed it closely when i picked it up and had already decided if there was frame damage to walk away from it
i needed to pick some low hanging fruit today
14 gauge steel is a dream to weld
  #176 (permalink)
Old 05-20-2013, 07:21 PM
37ford4dr's Avatar
bobs77vet
another 90 mins tonight....believe it or not but i havent really poked around this frame too much in the last year but this frame is in way better shape then i thought it was in.
the grinder will let you know when you are cutting good metal as opposed to thinner metal you can feel the resistance
you can see the sacrificial tail that i use to hold it in place
  #177 (permalink)
Old 05-20-2013, 08:16 PM
you are making really good progress on this beauty....
Do you plan to somehow treat the inside of the frame or just seal it up and keep it garaged?...I have a few places in the trailer that Im concerned about....I dont have a blaster...but I guess its in my future...What do you do with a long frame like that?
JP
  #178 (permalink)
Old 05-21-2013, 12:00 PM
37ford4dr's Avatar
bobs77vet
JP
I probably will do nothing to the inside of the frame just leave it alone. its had no love over the last 56 yrs and the inside of the frame where its not rusted through still measures a true 14 ga. for the rest of this coupes life i am sure it will be in a garage more then it is outside. For the outside i will just use a wire brush on the out side and then paint it with a rust converter. and then paint it. I suppose i could drill some holes in the frame and spray a rust converter soloution into it and then pop a cover into the holes. I have the material and the tools to do that. let me think about that for a while. i guess i could even do that now as i repair the rusted out sections.
  #179 (permalink)
Old 05-21-2013, 01:25 PM
Im impressed. Where you didnt have rust through the metal is actually okay...thats great...good to know...Im not so paranoid now about the trailer in some of those inaccessible spots.....
oh, meant to ask you...what are you using for rust converter and is that a magnet (not a magnate, thats a rich dude), that holds your ground clamp?
was that you with the clever idea to use a length of copper wire under the ground clamp also for a better ground?
good stuff.
JP
  #180 (permalink)
Old 05-21-2013, 03:39 PM
Built Not Bought
you can use a magnet from a cheap CB antenna ,used on for years ,don't need any thing else.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Battery for MGA 1961_MGA Electrical 4 08-23-2013 07:57 AM
'66 Mustang Coupe Resto my66coupe Introduce Yourself 2 09-08-2010 03:33 PM
1958 Coupe Deville kjbecker Introduce Yourself 3 08-26-2010 07:38 PM
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 07:36 PM
rear end on MGA 1961_MGA Suspension - Brakes - Steering 1 09-18-2003 02:54 PM
