Resto tutorial on my 1958 MGA Coupe - Page 15 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #211 (permalink)
Old 06-06-2013, 08:52 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
90 mins tonight cutting the repair panel and welding it in place and fitting one of the floor braces.
some times there are burrs inside the frame from the grinder cuts, i use a 3" grinder to grind those away
i need about another hour to finish the bracketry up.
  #212 (permalink)
Old 06-07-2013, 02:47 PM
Pats55's Avatar
Brings back great memories .It's nice to see guys that can do metal and fabrication work it's getting to be a lost art. In 1969 I put 283 inMGA. It had $15 fiberglass fan, big bucks back then, the first time I wicked it up it hit the top radiator hose and blew to pieces . I swear it's true story.
  #213 (permalink)
Old 06-07-2013, 06:54 PM
37ford4dr's Avatar
bobs77vet
thks pat nice Avanti!
right on 1 hr of work...tomorrow i will fully weld it in....next will be to remove any of the old weld nuts to make way for new ones.
  #214 (permalink)
Old 06-09-2013, 02:11 PM
37ford4dr's Avatar
bobs77vet
2 hours of grinding, i think i found something i like less then sanding....still need to make the small piece that bridges the rear floor rail and the side rail, where the blue tape is.
  #215 (permalink)
Old 06-10-2013, 02:55 PM
37ford4dr's Avatar
bobs77vet
about 3 hrs today.
lower a arm bolt
I get more done with a young buck doing all the work
i did this side
all the leaf spring bushings are pretty new and have not deteriorated
  #216 (permalink)
Old 06-12-2013, 08:41 PM
37ford4dr's Avatar
bobs77vet
about 90 mins tonight all the screws and nuts are "sorted out", my son spent some time today cleaning up the front of the frame
these are the next items to fabricate 6 of them looks like to me
  #217 (permalink)
Old 06-13-2013, 01:25 PM
37ford4dr's Avatar
bobs77vet
this sets up the bent piece to have the first hole cut by the plasma cutter all at the same level
you then have to chase the hole
this makes the last indentation
now we make the clip for the fuel line and brake line all as one piece then cut with a grinder
that was kind of fun
  #218 (permalink)
Old 06-13-2013, 06:33 PM
37ford4dr's Avatar
bobs77vet
about another hour tonight wire brushing the bottom of the frame, doing some grinding to where the spot welds were alittle bit rough and then painting the bottom of the frame with Jasco
  #219 (permalink)
Old 06-14-2013, 03:48 PM
37ford4dr's Avatar
bobs77vet
full day today my son and I.
wire brushed the frame twice, and wiped it down with cleaner and a scotch brite pad, removed shock absorbers and bump stops and front brake lines and 4 way brake union. and then primed it.
  #220 (permalink)
Old 06-16-2013, 11:47 AM
37ford4dr's Avatar
bobs77vet
about 2.5 hours today painting the frame, frame extension and cleaning the front spindles again.
this gave little better pivot point then yesterdays set up
  #221 (permalink)
Old 06-16-2013, 12:08 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
That frame is looking good! What a transformation.
  #222 (permalink)
Old 06-17-2013, 11:07 AM
37ford4dr's Avatar
bobs77vet
thanks, i figure i am no longer pushing the rock up the hill.....i will let the frame stay in the garage with the AC on for the next week so it can dry out and harden in a humidity controlled environment. the DC heat and humidity can be brutal on the drying of oil based paint.
The Following User Says Thank You to 37ford4dr For This Useful Post:
Valkyrie5.7 (06-18-2013)
  #223 (permalink)
Old 06-17-2013, 08:40 PM
37ford4dr's Avatar
bobs77vet
i figure the frame weighs some where in the 300-350 lb range with the steering rack and steering wheel on it. easy enough for the young bucks to pick up one end by themselves but a little heavy for dad...
this will allow us to move it out of the way easy enough so i can paint the rear end and reattach it. that is about exactly where the center of balance is for the frame.
  #224 (permalink)
Old 06-18-2013, 09:03 AM
boatbob2
Frame (chassis)
SO,did you sandblast that chassis??? or just paint over the rust???
  #225 (permalink)
Old 06-18-2013, 09:36 PM
37ford4dr's Avatar
bobs77vet
the frame was not sand blasted...it was pressure washed, power wire brushed, painted with a rust converter then power wire brushed again, then wire brushed twice by hand and wiped down with a scotch brite pad and cleaner then primed and then painted.
about 2 hrs tonight removing the emergency brake cable, removing black paint from nose of the rear end, degreasing it, draining the differential, sanding it and painting it with Jasco rust converter.
Battery for MGA 1961_MGA Electrical 4 08-23-2013 08:57 AM
'66 Mustang Coupe Resto my66coupe Introduce Yourself 2 09-08-2010 04:33 PM
1958 Coupe Deville kjbecker Introduce Yourself 3 08-26-2010 08:38 PM
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 08:36 PM
rear end on MGA 1961_MGA Suspension - Brakes - Steering 1 09-18-2003 03:54 PM
