Resto tutorial on my 1958 MGA Coupe - Page 17 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #241 (permalink)
Old 07-13-2013, 03:59 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
now that everything is cooled off i have cleaned them and polished the shafts. its also important in the assembly area to diagram exactly how it goes together so you dont have any oh crap moments.....
heres the diagram on the paper on the table and the photo proof....this is why i photograph everything it stops me from having to remember
  #242 (permalink)
Old 07-14-2013, 10:07 AM
37ford4dr's Avatar
bobs77vet
swivel pin goes in freezer..... steering knuckle goes in the hot sun on a black plastic bag. the pin gets a light coat of instrument oil
an hour later bingo......it went about half way in by itself then a light hammer tap and it went all the way home, then steering arm goes in while everything still has a temperature differential. if i hadnt painted it i could have put the steering knuckle inthe oven and them I bet it would have slipped right in
  #243 (permalink)
Old 07-15-2013, 09:48 PM
37ford4dr's Avatar
bobs77vet
cleaned and examined the pivot arm and polished the shafts
wire brushed the compression washers and painted them
poly urethane bushings
half of the spring pans get assembled with me standing
the threads for the ones that i have to put on kneeling get the threads chased with a cleaning die. this is different then a cutting die it only chases (cleans) the threads and doesnt cut anything
on a side note this was my grandfathers wrench the V was his initial i was given these last summer at a family reunion since the relatives knew i like working on cars, i have about 6 or 7 wrenches that were his. he had a large garage on long island in the 30s and passed away in the early 40s. these are my go to wrenches every chance i can use them.
this is one way to measure to make sure the distance tube has the proper clearances so it will doesn bind on the trunnion bushing
the mic slipped a little when i was juggling the camera but you get the idea
and the lower A arms and spring pans are in
  #244 (permalink)
Old 07-17-2013, 09:16 PM
37ford4dr's Avatar
bobs77vet
busy day today....checked the steering arm and swivel pin for cracks and repainted it, if you ever need to get fresh paint off of something just spray brake clean on it....
heres the dye penetrant, developer and cleaner from magnaflux. basically clean the part, spray the dye wait 20 mins clean it off and then spray the developer and wait 20 mins and then look for any cracks.that was $57 from grainger no need for the kit just get the cans
cleaned up the grease fitting and pumped new grease through them
you can see the old brown grease then the new stuff, no sense in contaminating all new stuff with old grease
I put the trunnions and distance tubes together following Barneys instructions. on these trunnions the bearings were just about brand new and had no measeurable wear on them, in fact I am not sure my hand reaming will be as tight as these are. and heres where i had to wait for some extra weight
200 lbs didnt do it.....300 lbs did the trick
nothing is tightend yet so please eye ball these things and make sure i didnt put anything on back wards....the thrust washers are inside the flanged washer facing the distance tubes
  #245 (permalink)
Old 07-18-2013, 09:43 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Those tools are a treasure , I have several Old snap on tools marked with the Blue point brand , Air tools and paint guns also.great job on the MGA ,
  #246 (permalink)
Old 08-14-2013, 11:28 AM
37ford4dr's Avatar
bobs77vet
thks will be getting back to it soon....i have some more parts on the way to wrap up the front end rebuild
  #247 (permalink)
Old 08-22-2013, 05:43 PM
37ford4dr's Avatar
bobs77vet
well the MG Gods are screwing with me just for fun I think
I got the part today and the top trunnion and the threads on the top of the swivel pin are good but the rest is disappointing. I removed the distance tube and bolt from the bottom but the trunnion still didn't move and when I examined it closely I could see the swivel pin was bent preventing the trunnion from turning, but sometimes the swivel pin can be straightened so I went through the effort to straighten it enough to remove the bottom trunnion and then I discovered that the bottom swivel pin threads were badly corroded so its not even worth the effort to try and straighten the swivel pin . time for me to have a beer (which incidently i bought to celebrate tonights accomplishments) and drown out the sorrows and start looking all over again. I badly need a good drivers side swivel pin and trunnions...does anybody have one that I can buy if you do please PM me, thks bob
  #248 (permalink)
Old 08-23-2013, 04:05 PM
37ford4dr's Avatar
bobs77vet
ok i have determined my origianl trunnions have no play on the good threads so it will be a new swivel pin
clamp steering knuckle in vise and remove nut on the steering arm and then replace it with one of the old castel nuts from the trunnion bolts to protect the treads and give it a good wrap with a hammer
put about 4 mins of O/A heat on the steering knuckle and some good wraps on top of the swivel pin
figure out your movements ahead of time that steering knuckle is really hot.....i am holding it with a pipe over the axle stub
i win
now immediately walk away and go post your success or else you will be touching those damn things and seeing your fingers turn white, so now i think its safe to go back out there
  #249 (permalink)
Old 08-23-2013, 05:24 PM
37ford4dr's Avatar
bobs77vet
i thought you might find this interesting thisis the trunnion off the bad swivel pin look closely and you can see the bushing is worn right through
and this is taking the bushing out of the one i am going to use
collapsing it on itself
using a press and a socket to get it out
i found my big plates on the bottom of the body work cart
and for the rest of the way i just used the vise and ead blow hammer
  #250 (permalink)
Old 08-24-2013, 10:34 AM
37ford4dr's Avatar
bobs77vet
well I have done something I never did before, I followed Barneys instructions and once again they made the job doable for a home shop. Barney is an MGA guru
I improvised a little since i wasnt sure how it make it all come togehter.
i decided to press the steel bushing in using my press and i made a guide so the bushing would go in straight
i made some reference lines just to make sure the hole didnt get side ways on me.
it worked very well , make sure if you chisel out the bushings to ream the edge if you made any gouges
i then dressed the ends so they were flush with the trunnions
next we follow Barneys instructions and use some tape as a guide
heres the mock up
heres my way to try and not chase a ball bearing around the shop
and it works
so for number 2 i am going to try somethng different with the ball bearing
and i used this the two nuts were tightend to tegether and the bolt would spin. you can see the end that mated to the recess of the reamer
and sucess about 2 hrs of work and the distance tubes fit very nicely.
  #251 (permalink)
Old 08-24-2013, 01:22 PM
37ford4dr's Avatar
bobs77vet
and to finish the days work....paint the parts and look for cracks in steering arm with dye penetrant and then paint it
red dye
if there was a crack it would show up here in the white
and it gets painted
  #252 (permalink)
Old 09-09-2013, 01:38 PM
37ford4dr's Avatar
bobs77vet
back at and glad to wrap up the front end well almost
got the new swivel pin and installed it
feels good to have this wrapped up
then I noticed the rubber water seal popped off...oh well that and the rear axle rebound strap are getting returned for new ones...
  #253 (permalink)
Old 09-22-2013, 12:27 PM
37ford4dr's Avatar
bobs77vet
replacement parts arrived and are installed, I have to stain the deck this week but after that its back to the car each night. next project will be reinstalling the brake backing plate and the front hubs.
  #254 (permalink)
Old 10-14-2013, 07:19 PM
37ford4dr's Avatar
bobs77vet
time to get back at it..
first we need to clean up the front hubs.
  #255 (permalink)
Old 10-15-2013, 05:35 PM
37ford4dr's Avatar
bobs77vet
well lets pry out the hub seal
cleaning tools
i clean up the inside diameter of the outer hub area just so there are no burrs
i use Barneys wau of removing the outer bearing
and then we do the inner bearing
and then its clean
Battery for MGA 1961_MGA Electrical 4 08-23-2013 07:57 AM
'66 Mustang Coupe Resto my66coupe Introduce Yourself 2 09-08-2010 03:33 PM
1958 Coupe Deville kjbecker Introduce Yourself 3 08-26-2010 07:38 PM
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 07:36 PM
rear end on MGA 1961_MGA Suspension - Brakes - Steering 1 09-18-2003 02:54 PM
