Hi Arn there are a couple of issues at play...newly sanded metal rusts really fast so they need to painted really quickly after that.....i need to have the inner sills in place before i can take the body off (if i decide to take it off.)
So i am test fitting the parts first and then will grind the areas and weld the inner sills into place. then i will decide later if i will sand blast the body or just sand it with a DA. |
some more effort today, removed the rear body mount bolt while I could see it and put it back in place with lots on antisieze so when I lift the body it will come off easy. cut out portions of the old body mount that were rusty and made a new piece. used plug welds to connect the body mount to the repair panel.
![]() ![]() ![]() ![]() ![]() I also added my repair panel for the back of the pillar ![]() I then moved to repairing a hole in the frame, I welded on a "handle" to the repair piecec to make it easy to hold inside the frame so I could weld it in place. I used the big vice to bend it to shape. ![]() ![]() ![]() ![]()
| The Following User Says Thank You to 37ford4dr For This Useful Post: | ||
John long (07-25-2012) | ||
background
How about a little history on you.What is your trade, how did you get your tinknocker talents, what led you to Morris Garages products, ect.?
This entire prossess has captavated not only myself but many others. I know the project is hard enough without taking the time to document it and share it with others but I for one look forward to each new installment. It takes me back to another time and I thank you for that. Keep up the great work ! |
the red headed boy in this photo is the one standing closest to the trailer in the beginning of the thread ![]() and this is youngest son who is the kid holding up the trunk floor
hard top believe its been about three months since i worked on the car last so i wanted to sart slow with an easy project so i worked on the door hinge plate.
here it is i drilled out the old screws and retapped the holes ![]() ![]() ![]() heres the retaining plate, nothing really fancy to make this. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
another quick moment in the garage
I took the wire brush to the area ![]() the mock up ![]() i always use the "best ground" set up when i weld ![]() some quick ugly welds
Glad to see you back at it...
My 75 TR6 actually has a vacuum retard distributor that retards advance with applied vacuum, I just plugged it off. This was due to the all mighty emmisions laws in full force by then, makes you wonder. Note I added a delco alternator, cured my "prince of darkness" blues right away. Might I add very nice work, way beyond a simple restoration. I did the front end on my TR and some minor engine fixes, I dare not touch a body hammer or paint gun. Impressive keep it going |
Your Project.........
Hi,love your tutorial,i can always learn from this great site,only thing i have to add,if it were me doing this project,i would spray OSPHO into all the places not accessible,after welding patch panels.Keep up the great work....
thks guys, i may be slow but i am very steady. this is the time of the year i really do alot of work...
i will check all those number on the igntion next time i fire up the engine. i try to use the engine as a releif from doing body work so i will wait until i get tired with the body work. all of the surfaces will get painted with a cold galvanizing spray and then a top coat of primer and paint. not many spots will be left with only a primer but when i have to weld two panels together it will have the weld thru primer only. i do plan to pull the body off the frame. well here is another bite of the elephant and may be the last thing i had to do before i can wrap up this side. this is the foot well body mount and bolt ![]() this is the template cut out of thin cardboard ![]() this is it laid out on a piece of austin healey 3000 frame i had laying around ![]() some slight persuasion happening ![]() ![]() some times things dont fit in the vise to bend when the sides are already bent so i used a piece of flat stock to make the jaws wider ![]() the rough shape ![]() all seams are welded here is the final fitting and welding ![]() to make a nice rounded fit around the bolt hole i used an old steel washer welded to the bottom of the bracket
Way cool...
when I want the best possible job I'll epoxy prime the sheet of steel I'm using(all of it ,before I cut anything) so the back side is coated ,second choice is using used hoods and other panels as my sheetmetal for patches because they are already done on the back side.Using weld thru is ok but not near as good...I only use weld thru on repairs that I'm using used parts and then it just around wheel wells and spots that I'll be welding...weld thru isn't so great when coating the back side of new clean steel...Your doing a fantastic job and this will help it last a lot longer,thats all.... Something I find myself doing all the time is fighting the urge to just weld the dang thing on bare because I want to see instant results and its tough to NOT just pick up an aresol can of weld thru or cold gal and spray it quick and go right to the welding (the fun stuff) using epoxy is way better but having the patience to spray and then wait till the nexy day to weld is incredibly hard...Thats why I spray the epoxy when I buy the new 4x8 sheet of steel or use old panels for the smaller stuff... |
can you weld through the epoxy primer? I have stayed away from the two part paints just for breathing purposes. i figure i inhale so much crap to begin with i just dont need to add to the toxic stuff i breathe. I do use the weld through primer and the galvanized primer only as a primer and then i top coat them.
happy Veterans day to everyone thanks for your service, I actually think about all those who came before me and gave me the right to vote when I am in the voting line. worked some more on the finishing the pass side. heres the need for the inner panel ![]() heres the template for the inner panel ![]() ![]() here I am bending the piece ![]() ![]() this is how you get extra leverage with brake ![]() ![]() ![]() now to fit the big panel and creat the flange< it its upside down in the photo ![]() ![]() these are deep C clamps I use on the sheet metal break and are good for many things ![]() ![]() you can see the good penetration by the heat discolortation on the panel
I gotta hand it to you ,theres not a lot of people that would take on such a lot of work...Personally,I enjoy it and wouldn't mind doing it every day if I could...
no,you cant weld thru the epoxy ,you just grind it a little on the edge your welding...If your spotwelding you just hold the new panel in place with screws or clecos and use a spot weld drill or a low angle drill to remove the epoxy only where it needs a weld... Your not using the weld thru as a primer on the body are you???? |
no the weld through is only where the panels are getting welded, i will use a self etching primer for body work. I like doing this also and a couple of hours through out the week keep me feeling happy....
well we are getting close to wrapping up this side.... heres the panel fitted in place for welding ![]() I added the supports for under the door posts and painted the inside with cold galvanizing primer over the weld through primer and then 3 coats of rustoleum glossy black ![]() here the interior with gloss black. I will use the mig welder for the welding on this and I will grind away the paint that is exposed prior to welding ![]() heres the test fit before the third coats of paint and I will let dry before I weld it in place.
What a great day yesterday was! I got to go on a road trip with my oldest son, meet fellow NAMGAR member George Kress , work on an MGA and Tour George's car collection. George had been watching my post and realized he had exactly what I needed and offered a donation to the cause of a front shroud, front frame extension, and unbent radiator. I glady accepted this generous offer! Our road trip started at 6:00am yesterday and we reached George's shop by 9:30am. We started the dissassembly process and by 11:20 the three of us had wrangled the front end off the parts car. After we got the Shroud loaded into the Pick up the fun really started and we toured George's extensive car and parts collection and enjoyed every moment of it. About 12:30 we had everything loaded up and headed back home. It was a great Day with my son and it was really enjoyable meeting George and I look forward to seeing him again at one of the NAMGAR car shows....maybe even with my coupe wearing the new front end!
| '66 Mustang Coupe Resto | my66coupe | Introduce Yourself | 2 | 09-08-2010 03:33 PM |
| 1958 Coupe Deville | kjbecker | Introduce Yourself | 3 | 08-26-2010 07:38 PM |
| 1958 Cadillac Coupe Deville | bigwoodbass | Engine | 3 | 03-25-2007 07:36 PM |
| Battery for MGA | 1961_MGA | Electrical | 1 | 05-30-2004 02:15 AM |
| rear end on MGA | 1961_MGA | Suspension - Brakes - Steering | 1 | 09-18-2003 02:54 PM |
