Front frame extension
well i got to work this am on removing the front frame extension from the shroud and worked on it a little bit to bring it back into tip top shape. one of the bumper mounts got bumped when the car got moved into the shop and it broke off when i removed the frame extension and it will get welded back on later this week ![]() here is how i will remove the bolts ![]() i take this stuff serious and i gear up for it and use a full face mask, hearing protection and thick leather gloves, not like these numb nuts on TV who use no protection ![]() ![]() here it is removed ![]() all and all its in pretty good shape and way better then my mangled one on the coupe ![]() here are the side extensions hammered back to shape, it didnt take much ![]() working out a little dent, we wont let momma know i am using her potting table... ![]() here it is wire brushed ![]() ![]() I printed off of Barneys site the front frame extension dimensions and will use that as a guide to finishing the reworking of the piece |
time to wrap up this side.....tonight I welded the inner sill and patch panels into place. I spaced the welds about 1" - 1.5" apart and started at the middle and worked my way out, metal has a way of growing on you when it gets hot. tomorrow i will go back and fill in all the voids and grind the welds down
heres the trial fit ![]() heres the welder for the sheet metal using .025 wire, I have welded more with this welder then you can possibly imagine and it keeps on going. ![]() heres the last of the welding, its important to have lots of clamps or vise grips holding things tight
I finished the inner sill welding tonight I used a wire brush to make sure that there was no paint left bewteen the areas I was welding>
![]() its important to inspect the welds....if you look closely you can see my bead in the middle is a little too high and moves off the bottom piece. look for the straight shiney line. ths is no big deal just lay another bead along side of it. ![]() heres a good example of the original tack weld and then the follow up running bead ![]() now just have some grinding to do and we can paint it
well while the turkey was cooking I snuck out side for an 1.5 hrs...I post these photos to try to give some examples of how to bend metals, there are lots of different techniques to use and I am certaintly not a professional body man nor a metal expert but I do have fun working the metal and i think sometimes the best thing to do is just to do it
the need... ![]() clamp the metal to cut it with an electric shear ![]() ![]() you can also use the break to hammer form the metal ![]() ![]() ![]() some times the clamps will not reach where you want them to go so just tack it and use a hammer to flatten out the seams ![]() ok this is just because i can...i am filling up a gap ![]() ![]() ![]() dont let inexperience stop you from learning this stuff, I have taught my self all I know and I have built up my tools over my lifetime a couple at a time |
Lincold weld pac 100..........
Actually that welder is a little small on amps,to weld thicker metal with it,you really need to heat the metal with a torch first.
Hobart...........
Sorry,didnt spot the Hobart in the photo...........
that Hobart is a sweet welder I would recommend that to any one. I am thinking Santa may bring me a spool gun for it and place it under the tree this year HO HO HO
a few more nibbles of the elephant tonight, I used the O/A rig to put this back together and to bend it back into shape I still have a little more to do tomorrow to it. ![]() ![]() ![]() ![]() ![]() ![]()
Dont know if you need anything for your A if you do i order parts from www,VictoriaBritish.com normally 60% the cost of moss usally same part # and manufacturing co they have catalog and website,dont know if they will work but i have a 1969 MGB GT with 5 wire wheels knock offs and hubs along with good engine twin carb OD trans lots if other parts my body it too rusty to repair i bought as a package do not need
thks I have their catalog and will keep that in mind. where are you located? the OD trans sounds interesting.
today everything fought me.....so I am calling it quits after a few hours, some times you have to know when to back off.... I did get the frame extensions bent back to the right dimensions though reworked side ![]() original good side ![]() [IMG]http://img.photobucket.com/albums/v494/bobs77vet/MGA%20Coupe/Body%20work/IMG01031-20121123-1737.jpg[/IMG |
I am sure that the hobart plasma cutter is top notch, i have a cheapie inverter one and it works great.
well I decided to try my luck again and it went much better, I fixed the hole in the tubing on the frame extension and then primed it. ![]() did a little bit of grinding and test fitted the other bumper bracket ![]() and then to the primer, i am so old i still think of it as red lead primer
I am located in Fairmouny Ga approx 65 mi notth of atlanta 60 south of chattonooga
thks let me see how my stuff works and if i have a need i will give you a shout
another hour or so this am after little Joe went back to college cutting out the rust ![]() the filler piece from scraps ![]() the set up ![]() the tack ![]() the copper so it doesnt burn through and stick to my anvil ![]() voila ![]() this is the last time i am going to spend time looking for sharpies, my mig pliers or the ground strap use graph paper to line it all up ![]() ![]() painted ![]()
woohoo never put a grinder with a cut off wheel in the hands of a 55 year old....
looks like the bottom of the frame horn is tweaked slightly ![]() I took many photos of hood gap for reference pictures ![]() removed old frame extension ![]() comapred it to the new one and they line up where they should and are different where i would expect them to be made some imaginary cut lines way forward of where i think i am going to splice them ![]() and then made a different cut line even more ahead of those ![]() ![]() spent a few more minutes fitting the frame extension i just had to hammer down one of the front frame horns a few mm's took about 3 hammer swings to get it right...time to contemplate the next move
| '66 Mustang Coupe Resto | my66coupe | Introduce Yourself | 2 | 09-08-2010 03:33 PM |
| 1958 Coupe Deville | kjbecker | Introduce Yourself | 3 | 08-26-2010 07:38 PM |
| 1958 Cadillac Coupe Deville | bigwoodbass | Engine | 3 | 03-25-2007 07:36 PM |
| Battery for MGA | 1961_MGA | Electrical | 1 | 05-30-2004 02:15 AM |
| rear end on MGA | 1961_MGA | Suspension - Brakes - Steering | 1 | 09-18-2003 02:54 PM |
