Resto tutorial on my 1958 MGA Coupe - Page 8 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #106 (permalink)
Old 02-04-2013, 08:19 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
yes a 73
one more hour to fix the last piece of rust on the front shroud
and the piece from the donor inner fender
  #107 (permalink)
Old 02-06-2013, 04:40 PM
37ford4dr's Avatar
bobs77vet
4 hrs today ....I really took my time to make sure i didnt screw up
heres how you can make lines that are transferrable
you can get the idea of how the splice will work
really taking my time so i dont have an accidental over cut
slowly you can see the gap getting smaller
so heres the big gap that needs to be made smaller
getting close and i used a 1/4" rod to transfer the cut line
so i used those alinging pieces inside the bonnet frame support and you can see the gap getting closer
at this point both sides are really close
so to make the final cut its all clamped in and i very slowly use the cut off wheel and make a cut right in the middle of splice line
close to the final splice the rest of the trimming will be done with a hand file
final gaps
and i need to tweak this alittle
here i am using copper in between my temp splice and the two sections of the bonnet so i can weld the outer drip rail
all tacked in place and time to stop, everything went very well so some times you need to know when to stop
  #108 (permalink)
Old 02-08-2013, 07:08 PM
37ford4dr's Avatar
bobs77vet
spent an hour or two fiddling with putting the hood on and tweaking the drivers side area where the two halves meet
I needed to elongate the bonnet hinge holes a little bit so I conjured up this idea.
  #109 (permalink)
Old 02-08-2013, 07:54 PM
deadbodyman's Avatar
Wiki Edits: 11
I think your doing great ,I can give you a few time saving tips if your interested...
I still find it hard to believe theres someone else out there that has the courage to take on the dead ones... keep up the good fight...I almost bought this one last year.thought it was a Healy...
ID:	71207   Click image for larger version
ID:	71208   Click image for larger version
ID:	71209   Click image for larger version
  #110 (permalink)
Old 02-09-2013, 07:36 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
DBM is that a bug eyed sprite.
  #111 (permalink)
Old 02-09-2013, 03:35 PM
37ford4dr's Avatar
bobs77vet
I am always up for tips, I do this for fun so some times the easier ways of doing things i have to discover....I had a big Healy I really liked it.
496...That is a later model MGA
I would settle for having the body off by spring time...
spent a couple hours this am and I welded up the two halves today there is a lot of tension in those joints, I think I will not grind them until after the body is taken off so I can weld the bottom side with a nice seam. and then after grinding If I need to touch them up I will use a TIG on it.
here is my handy dandy anti burn through gizmo made out of Bonnet scraps
i definitely got the gaps where they should be
  #112 (permalink)
Old 02-10-2013, 06:39 AM
Wiki Edits: 11
The gaps look great...That was an old 62 MGA .A bit too rough even for me. when I saw how you cut the nose of it remended me of it (first pic),,,it's still there...
  #113 (permalink)
Old 02-11-2013, 09:44 AM
37ford4dr's Avatar
bobs77vet
well finished up a little this weekend and welded the last repair panel on the front pass side where the bottom of the inner fender atraches to the end of the inner sill. and worked on finte tuning the Bonnet gap and putting the bonnet catch on. i think it took me longer to adjust the bonnet then it did to graft the front end on....
  #114 (permalink)
Old 02-11-2013, 09:55 AM
37ford4dr's Avatar
bobs77vet
  #115 (permalink)
Old 02-24-2013, 09:46 AM
37ford4dr's Avatar
bobs77vet
not too motivated today I have cold or something so we are picking low hanging fruit....kind of the crap work that you never like to do anyway, I force myself on days like this to do an hour or so just to get it out of the way.
so i primed the welds on the front end graft and removed the divers door and had to drill out all but three of the hinge and catch bolts. there were a spacer on each door hinge
  #116 (permalink)
Old 03-02-2013, 02:39 PM
37ford4dr's Avatar
bobs77vet
picked up my youngest son from college to day for spring break .....my goal is to have the body pulled off before he goes back to school. 4hrs working on the drivers side sill repair. i decided to start at the front and work my way back.
heres the donor panel
the salvaged repair piece
same method of grinding off the spot welds and peeling off the metal
the repaired repair panel
trimmed and primed
rough welded in place, grinding will come on another day
  #117 (permalink)
Old 03-03-2013, 02:25 PM
37ford4dr's Avatar
bobs77vet
4 hrs today kicking some butt.....
cut away the rust
the template to make the part, i am not sweating the bottom length and i am making to too long on purpose and will trim it later
this is the offset flange
here is the back side primed with cold galvanizing compound you can weld through this but it really sparks alot
while the paint is drying i removed all the body bolts and was surprised how easily they came out and the rear body mount is in great shape
the front needs some work though
made up new piece and primed it with weld through primer
while thats drying i went ahead and removed the rusted out section
same trick i ground off the old spot welds. what looks like holes is actually shiney metal
after everything is cut away the new piece is made and flanged and primed
and welded in place one step closer to being done...
  #118 (permalink)
Old 03-03-2013, 07:25 PM
37ford4dr's Avatar
bobs77vet
1 more hr needed to wrap things up
i used a piece of angle iron to make sure that i had a nice straight and tight seam
that thin line is the middle piece nice and straight
and of course you need to have a mock set up admittedly this was for my satisfaction
so i paint the inside of the inner sill
i had to move some stuff around to get the welding cart over behind the MGA where this use to taking up residence... what would a garage be with out a sons custom motorcycle project??
  #119 (permalink)
Old 03-04-2013, 09:52 PM
37ford4dr's Avatar
bobs77vet
3 more hrs of work..had my son helping me..I welded up the inner sill, while he removed the rear bumper horns and the 6 inner boot body/frame attaching bolts.one of the rear bumper horn extension bolts was a major PITA and we wound up cutting it off. i drilled two 1/8 aligning holes in the bonnet hinge mounting plate. cant believe so little work took so much time
  #120 (permalink)
Old 03-05-2013, 07:34 PM
37ford4dr's Avatar
bobs77vet
2 more hours tonight wrapping up the door posts, all of the grinding and making the welds look pretty will happen after the bodys off the car
and i added an extra support brace for good measure
« G-body '80 Cutlass | - »
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Loose Ctrl
Battery for MGA 1961_MGA Electrical 4 08-23-2013 07:57 AM
'66 Mustang Coupe Resto my66coupe Introduce Yourself 2 09-08-2010 03:33 PM
1958 Coupe Deville kjbecker Introduce Yourself 3 08-26-2010 07:38 PM
1958 Cadillac Coupe Deville bigwoodbass Engine 3 03-25-2007 07:36 PM
rear end on MGA 1961_MGA Suspension - Brakes - Steering 1 09-18-2003 02:54 PM
