RESTORE VS Lucas Oil - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2009, 10:27 PM
64newyorker
I was wandering which oil additive was better for compression and performance restoration, RESTORE or Lucas Oil?
thanks
zakk
Old 06-30-2009, 10:38 PM
Wiki Edits: 31
Restore works good, Lucas cavitates the oil and causes foaming
Old 06-30-2009, 11:09 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Matt,
How does the Lucas oil cavitate? How can you tell that the oil is foaming?
Old 07-01-2009, 01:11 AM
SSedan64's Avatar
Originally Posted by alittle1
Matt,
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old 07-01-2009, 08:29 AM
302 Z28's Avatar
Tell us what your aim is. IF your just after rasing compression to get rid of it, nothing beats plain old STP for raising the oil viscosity.
Vince
Old 07-01-2009, 08:51 AM
Irelands child's Avatar
If you want a viscosity increase, yes, STP will work.
BUT - these super performance enhancing elixers, all of it regardless of make, the products of snake oil salesmen like the late Billy Mays. If you want to increase compression and/or performance, you have to rering as a minimum. Then, if you really want to change (or correct) the performance, then a rebore, new higher compression pistons, new or rebuilt heads and a decent performance camshaft.
The crap that Carrol Shelby hawks - absorbs into the metal - not a chance!!!!
Dave W
Irelands child
Old 07-01-2009, 10:36 AM
dinger's Avatar
Dave W
Good advice! Desperate needs for inexpensive fixes usually lead nowhere. Some cause bigger problems in the long run.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 07-01-2009, 10:53 AM
Wiki Edits: 31
IDK, a mix between restore in the oil, and seafoam and marvel mystery oil periodically dumped down the carb of my '65 Rambler, made the worn out engine more drivable... Marvel mystery oil actully increased the vac from 6hg to 10hg.. you could watch it on the gauge as you poured it if it was hooked up in a line, and it worked for a couple weeks, then needed redone.. restore seemed bump the compression a little.. about 5-10 PSI per cylinder ranging from 135 PSI to 150 and b4 they were as low as 120... engine was deffinetally stronger and more drivable with the additives, and 2 pumps of the pedal and touch the key and it would start every time without a choke.. it was disconnected due to a broken heat tube... I don't think there were any ill effects to the engine.. it left a blue cloud behind everywhere it went, but it never missed a beat
Old 07-01-2009, 01:27 PM
My guess.....that you cleaned some of the sludge off the rings, i.e. allowed them to spring back against the cylinder walls - but it wasn't long lasting as you noted. Much of those snake oil solutions are not much more then a petroleum based solvent material.
Irelands child
Old 07-01-2009, 01:59 PM
Wiki Edits: 31
yea, I know the rings were toast and it's possible that the seafoam did the cleaning.. the valves were also toast, and I think the mystery oil burning in the chamber cleaned them and allowed them to seal a bit better, but over the week or 2, it degraded.. each time it lasted about 500 miles or so.... Seafoam just helps to clean carbon out, and it works good... I ran both seafoam and marvel mystery oil thru my '51 Chevy ( just mixed them with the gas like they say you can ) and along with the Autolite plugs I put in, it runs much better now, even tho it ran good b4
Old 07-03-2009, 04:02 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Restore seems to work on an engine that is worn, but not quite worn out yet. There is a point where it's worn so bad that it doesn't help. But it does seem to boost compression and reduce oil consumption slightly -- for a while. Nothing you pour in will be a permanent fix, but might get you another year of driving.
I don't buy the Lucas foaming and such either. It might do it almost straight or churned in a blender, but I've been running it for YEARS in my motorcycle. At least 50,000 miles over the last 10 years, and it still performs great. Engine oil is also trans oil, and if I don't run Lucas at every other oil change (I don't use it for every change) the trans will make a bit of noise. It was doing that before the Lucas, so the Lucas isn't the cause.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
Lucas motor oil? bigolblackie Engine 54 10-24-2010 08:12 AM
oil leak rb8179 Engine 11 06-03-2006 04:07 AM
gas prices and hotrodding ! engineman302 Hotrodders' Lounge 87 04-24-2006 09:27 AM
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 08:36 PM
