Restoring floorboards - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2006, 09:52 PM
64Joker's Avatar
64Joker
Im restoring my floorboards on my 1964 Impala, after stripping the floorboards down to metal, what type of application should be applied to the metal prior to covering with heat insulation pads? Thanks in advance - Al
Old 07-01-2006, 06:53 AM
Wiki Edits: 31
any rust coating, POR 15 is the most common, and 1 of the most expensive, but there are others
Old 07-03-2006, 11:33 AM
gdubstub's Avatar
Old Crusty Streetrodder
Don't apply rust encapsulators (POR 15, Eastwood Rust Encapsulator) over bare metal. The paint won't stick to bare metal. I learned this from experience and then from the Eastwood folks. Check out Eastwood for all kinds of rust prevention and metal prep chemicals but all I did was shoot JUST the rusty areas with Rust Encapsulator, then shot the entire floor pan with Chassis Black (any epoxy will do...), then applied seam sealer over all the seams, top and bottom. The floor pan has been rust-free for years.
George
Restoring a Datsun alex_0227 Hotrodding Basics 39 03-27-2007 02:04 PM
restoring 1941 ford coupe foster 1941 Introduce Yourself 4 02-01-2006 01:27 AM
Does Anyone Know Where I Can Get Some Floorboards For My 1934 Chevy?? mistermuscles Body - Exterior 7 12-13-2005 06:03 PM
I'm Restoring a 1971 Olds 442 Benji Hotrodders' Lounge 6 01-03-2003 04:00 PM
Restoring or Building The1andonlyBuck Engine 1 02-16-2002 03:56 PM
