Restoring Gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2013, 10:13 AM
andrewakessler's Avatar
Restoring Gauges
Hello,
I have a set of 1936 Pontiac gauges I'm looking to use in my truck build.
I have the gauges apart, and the internals seem pretty simple, but I can't find any info relating to testing / fixing gauges.
Is this the type of thing that should be sent out for possible repair, or does someone know of a obscure book / website I can check out.
Thanks,
-A
Old 01-22-2013, 02:04 PM
Lots of places do this. Expect to pay about ten times what you think it should cost (ie, several thousand bucks).
Old 01-22-2013, 02:13 PM
I believe one such company is called U. S. Gauges. I think the cost driver is in the artwork. For more common vehicles, I'd guess more like $1000 - $1200. I checked with them about 15 years ago on the gauges for my 37 Chevy pickup, they said about $650 at the time.
PatM
Old 01-22-2013, 02:14 PM
techinspector1's Avatar
Wiki Edits: 326
Call some of the shops and ask what they charge. Here's one to get you started.....
Contact | D&M Restoration
Old 01-22-2013, 02:37 PM
Excuse the noob question, but are mechanical gauges really that hard to fix on your own?
I can certainly understand having some trouble with a speedometer, but the gas, oil and temp gauges seem to be fairly straight forward.
-A
Old 01-22-2013, 02:43 PM
Wiki Edits: 326
-A
I'm thinkin' that restoring the faces is the most difficult part.
Old 01-22-2013, 03:12 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Don't forget that Classic Instruments can help too-
Welcome to Classic Instruments
Old 01-22-2013, 05:03 PM
They are the ones who quoted me several thousand bucks.
Old 01-22-2013, 05:34 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Their was a guy building custom gauge faces for modern cars (namely his miata) over on revlimiter.net. Using some careful planning and relatively basic photoshop skills he was able to make new faces using two pieces of transparency film with a piece of paper with the new gauge faces sandwiched between. Because I assume your gauges aren't back-lit, it might be a little easier.
His tutorial is down now (his intellectual property was being stolen and used to make cheap aftermarket gauges apparently) but I'm sure hunting down a similar looking font and printing some new gauge prints out on a quality medium, you should be able to replicate the look somewhat.
As far as rebuilding them, someone had to learn somewhere. Maybe look for a book on Amazon or (my usual decision) just dive right in and see what you can learn first hand?
The Following User Says Thank You to Valkyrie5.7 For This Useful Post:
andrewakessler (01-23-2013)
Old 01-23-2013, 07:32 AM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
i recently purcheced my guages frem classic inst, $799 for 53 chevy pu they have volt meter not amp ,suposeably fire hazard ,these are Very nice and work great mine are all electronic,also come with wiring senders and sensors ,they have a list for many cars yours might be one ,also speedometer is adjustagle for different tire size and gear ratio .
Old 01-23-2013, 08:47 AM
In case this info will help anyone else, I was able to find a couple old gauge service manuals on "http://www.imperialclub.com" (great site btw).
The site has individual pages for these manuals scanned in, so I downloaded and compiled them into standalone PDFs for ease of use.
Gauges-Service_Reference_Book.pdf
https://www.sugarsync.com/pf/D1552739_63296114_66762
Thermal-Electric Gauges.pdf
https://www.sugarsync.com/pf/D1552739_63296114_66764
I'm going to try and post other info I find on gauge restoration as well, since the info seems to be so limited.
The Following User Says Thank You to andrewakessler For This Useful Post:
Valkyrie5.7 (01-23-2013)
Old 01-23-2013, 04:34 PM
Wiki Edits: 15
Definitely printing these out and storing them in the shop. Thanks!
Old 02-03-2014, 09:41 AM
The site I originally posted the PDF links on is starting to charge for storage, so I've moved these links to another more stable site.
https://dl.dropboxusercontent.com/u/...rence_Book.pdf
https://dl.dropboxusercontent.com/u/...c%20Gauges.pdf
Old 02-03-2014, 09:51 AM
Wiki Edits: 27
newer internals ?
Factory Five Racing has instructions in ther build manual on how to dissamble the donor car Mustang gages and mount them in the "Cobra" dash panel and using radio Shack led's for lights.. I swapped in a 60's ford truck gages in my Willys in the 70's. When I worked in a GM dealership the service manager used to solder wires on the printed circuit board for repairs. I have been thinking about using the GM gages and putting them in the T bucket project, GM V6 5 speed donor car parts.
New to restoring Phil750 Introduce Yourself 2 07-03-2011 01:03 PM
Restoring factory gauges mc73DD189 Interior 2 06-29-2010 04:57 PM
restoring a 67 camaro 67camarocarrie Introduce Yourself 2 08-09-2006 10:42 PM
new to restoring monk81 ta Hotrodding Basics 4 11-26-2003 07:53 AM
Restoring a 41.. dhaza Hotrodders' Lounge 5 12-12-2002 05:43 AM
