Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - restoring low compression??to pass emissions
Old 05-06-2013, 09:08 PM
briansansone's Avatar
briansansone briansansone is offline
4 chevys and a ford
Originally Posted by oldbogie View Post
If it won't hold compression due to valve leakage, there isn't any elixir on the market that will fix that.
Most states have a proviso that if you take a failed vehicle to an approved repair station and spend up to some limit 100-200 dollars usually and that can't fix it, they will then issue a license tag. That may prove to be the cheapest solution to the problem.
Bogie
its $750 per year in atlanta.
