Restoring my 55 Chev Bel AIr-- - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2012, 08:08 PM
What is the best body filler these days?
Thanks
Dave
Old 10-09-2012, 08:28 PM
novafreek6872's Avatar
Nova Guru
Evercoat Rage Gold seems to be very popular choice I've noticed.
The Following User Says Thank You to novafreek6872 For This Useful Post:
dinger (10-11-2012)
Old 10-09-2012, 08:56 PM
302 Z28's Avatar
Ditto. If filler with a little more strength is needed check out Marine Tex.
Marine Tex, epoxy resin, adhesives, silicone grease, engine treatment, cleaner, repair, bond, fill, seal, fiberglass, aluminum, plastics, Starboard, wood
Vince
Old 10-09-2012, 09:00 PM
Faith - Respect - Trust
I agree, rage gold is an excellent filler made by "Evercoat". It is a little pricey, but like many things in life you get what you pay for. Beware of bargan, department store brands that save you a few dollars, you have a good chance of cursing the product when you start blocking a panel and it takes forever to sand. Also, I have never had a bleed back (bleed back is when the colour in the hardner comes through after you paint... rare but I've seen it happen on the lower end filler) problem using this product.
In short, I would highly recommend this product.
Old 10-10-2012, 09:50 PM
mitmaks's Avatar
Last journal entry: Grille
I like to use sealer to reduce chance of any bleed throughs, sand scratches,etc.
Old 10-10-2012, 10:15 PM
I agree sealer will minimise your chances of getting bleed through and help with any sand scratches that might show up. However, any time i do any type of major restoration I work diligently on the prep, the whole car is primed, sanded with the proper grit and go right to paint. The reason for this is that I feel the base will lay down flatter and give you a better shot at a flat, shiny clear finish. Also, the longer your in the both the more chance of getting dirt in your paint... don't get me wrong, sealer does have it's place.
Old 10-11-2012, 07:07 AM
Wiki Edits: 27
marine grade
My older brother is 79, doesn't finish cars as fast as he used to, He says he uses marine grade filler that won't absorb moisture and start rusting underneath since sometimes the cars will sit for a while as he takes a vacation to go visit his grand kids,
Old 10-11-2012, 10:22 AM
302 Z28's Avatar
That is what Marine Tex is.
Vince
Old 10-11-2012, 12:27 PM
I like the Z-grip myself. Not as expensive as some of the other fillers, but much better than my Dads OG Bondo brand. If I have it, I'll put the Rage over the top, it seems to finish a bit nicer and seems to sand easier by hand. If you're using a primer with some fill to it, I wouldn't worry. YMMV
Old 10-11-2012, 09:04 PM
I will second on the Z grip filler as that is all I use. Spreads on nice and smooth and sands pretty good too, and not as expensive as the rage extreme.
Old 10-12-2012, 06:25 AM
deadbodyman's Avatar
Wiki Edits: 11
Pretty much all of evercoats products are great and you cant go wrong...
I prefer Z-grip along with ez sand finishing putty,a very good combo.
On restorations (only) I'll strip to metal then epoxy prime THEN do the filler work...
Old 10-12-2012, 07:30 AM
There was a 3M filler I got to try at a body shop; apparently some rep dropped off a sample...it was amazing stuff, but no one carries it around here. QBR or something I think it was called.
Old 10-12-2012, 11:46 AM
mitmaks's Avatar
To make a paint job stand out from the rest, I'll seal it and then wetsand sealer followed by paint and clear.
Old 10-12-2012, 12:03 PM
Yes mitmaks, that will work, and yes you will have a flat finish for your paint. It may be one of those preference things. I prefer to use my primer as a ground coat, I pay close attention to detail regarding what's under my primer. What you are suggesting, there is nothing wrong with that.
Air Ride on a 1953 chevy bel air LowClearanceCustoms Suspension - Brakes - Steering 1 10-16-2008 03:40 PM
New 56 Chev Bel Air Owner kansas Introduce Yourself 4 05-14-2006 02:28 PM
How to move forward with a 56 Chev Bel Air kansas Engine 5 05-14-2006 01:37 PM
'55 Chev Bel Air - Looking for upholstering george freeman Interior 4 04-16-2006 12:38 PM
stealth cool air intake system for 55 Bel Air Berliner Bel Air Engine 9 11-30-2004 03:32 PM
