I just suggested the same thing to LS1-Volvo (see my post), but I just kinda came up with it in answer to his question, I don't know if it would work or not, but it wouldn't cost much to try. Go to walmart and get a can of duplicolor bed liner spray and spray a few coats on until you have a nice buildup. Then if your interior isn't black, paint it with fusion or vinyl die, or use bulldog and paint. Again, I have never done this or even heard of it being done, but it seems like it would be a cheap fix for the time being anyway. Good luck.
I would try to find some in better condition in my local wrecking yards.
Strummin |
I've ran into the exact same problem on my 79 t-type regal. What I did was scrub all the residue crap off and coat with a light layer of fleckstone from walmart and let it dry a few days and then coat it up really well with the color of your choice and then over that with some good quality clear coat looks very nice. I also let this sit under heat lamps for a few days to make it rock hard just dont let them get to hot. mine has been this way on a driven car for nearly 10 yrs with no problems. try it out on some scrap see what you think.
My father has a 65 dodge coronet wagon,same problem.What we did was this.His plastic panels were cracked,so we superglued the cracks.Then we cleaned the **** out of it.Got the spray-on bedliner that you can color.We mixed in 4 oz. of paint(ferrari red,same color as his car) and sprayed it.It looks great.
I just did my '80 Malibu interior... same condition as you describe.
I sanded off the crumbly top layer, washed the pieces, cleaned with lacquer thinner, air dried... then sprayed with a bonding agent, followed by a couple coats of vinyl dye. The texture isn't quite the same as original, but nobody would notice on my car. I don't know how well the dye would stick to undercoat, but it seems like it would match the OE look. I got the vinyl dye at a local auto paint store, they just looked up the color codes and made me a couple spray bombs. Perfect color match and has the correct gloss as original. The bonding agent was also a spray bomb, it was recommended at the store. Just put on a light mist right before the dye. |
| Recent Interior posts with photos |
| working with plastic panels? | andy_wh2000 | Body - Exterior | 2 | 02-20-2006 10:34 PM |
| Plastic Interior Panels | 70chevy | Interior | 3 | 07-13-2004 08:40 PM |
| restoring engine compartment plastic (fender wells) help | 406 ss monte | Engine | 3 | 03-23-2004 02:24 PM |
| Upholstery over Plastic Panels | jrocco | Interior | 1 | 10-01-2002 08:06 PM |
