There are two good books that will give you an education in qjets. Cliff Ruggles is the book I chose. He also has a q jet forum at cliffs high performance dot com. He rebuilds q jets and will sell you parts, and he'll answer questions on the phone. Start with the book and read it several times, it'll answer most of your questions.
I'll see about getting that book.
One thing I noticed on this carb tonite is that even tho it IS a 75+ model carb (as indicated by the model number starting with a 170 instead of 70, and being removed from a 78 HD 454) it does NOT have the APT adjustment screw in front of the power piston. This really bugs me alot as I was really hoping to use that adjustment to my advantage. I suppose the only way to adjust the APT would be with one of four different springs that are available. Not much of a fine tuning adjustment that way. I am thinking maybe I need a different/better carburetor to start with. |
There's usually (depending on the carb, not all are the same) about a 30 number difference between the jet and rod. This can change depending on the air bleed arrangements, etc. but gives you an idea of just how much difference you may see between the jet and rod. |
I'd never heard of it being in the base plate before. |
Thanks for the vote of confidence. The baseplate mounted APT is easier to get to, IMO. I like to free it up real good and use teflon tape if needed on the threads to keep the screw threads tight. There's often carbon built up around the lifter arm, try to get all of that cleaned out so the lifter arm is free to move w/the adjustment screw. It's only staked in position so take care not to upset this while cleaning it.
Before removing the APT adjustment screw, get a baseline measurement for the APT "lifter arm" so you have something to go to if need be. The depth rod of a caliper works good for this. Another adjustment that's not commonly recognised is the idle air bleed screw that is present on some carbs. It's located under a triangular piece of thin spring steel where the front vent is located, seen in the Ruggles book cover below:
I like the idea of the base plate mounted APT adjustment also. I have two identical carbs (17058212) and one of them I have right here beside me (disassembled). I do see the nasty carbon buildup that you're talking about and as soon as I saw it (when I looked at the APT earlier) I knew it would need to be cleaned. I dont think at this point that the adjuster would work at all with all the gunk in the area.
I'll be sure to get a base line setting before I mess with the APT screw. I'm not totally sure if it needs to be adjusted or not, but it cant hurt to change it a little at a time until it has a negative affect and then change it back a little I wouldn't think. This carb just seems to run too rich IMO. Also, It looks like my carb does not have the idle air bleed screw adjustment. Sure wish I had an A/F ratio monitor. That would help alot. If I could get it to 14.7:1 at cruise and 11.7:1(?) on acceleration that would be awesome, but to get that good of a tuning I fear i'd probably have to have fuel injection. Thanks for everything so far!! |
BTW I'm really starting to like this carb - still wish I had EFI but this is pretty close.
I am thinking of trying to find parts for use with alcohol fuels to install in this carb since there is so much ethanol in our fuel. I'm pretty sure its causing me some problems with ALL my carb'ed engines. I'm assuming the alcohol compatible components are compatible with gasoline still?? Surely they are... |
A couple links, etc. that may be of some use: • Q-jet rebuild w/photos- HERE. • Q-jet Carb Adjustments- HERE. • Manual w/exploded view- HERE. • Gessler has most if not all of the small, hard to find parts. • Ruggles has quality parts and rebuild kits and services like primary bushing installation. He does correct restoration of Q-jets, too. Consider buying his book "How to Rebuild and Modify Rochester Quadrajet Carburetors". Another book is By Cliff Roe, called "Rochester Carburetors". Most say they'd probably get the Ruggles book first. • A thread here on Hotrodders that has some good info and photos- Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level) Last edited by cobalt327; 07-05-2011 at 08:48 PM. |
Yeah its not very easy to get gas here without ethanol in it. Missouri state law REQUIRES all gas UNDER 91 octane to contain at least 10% ethanol. 91+ isn't required to have it, but alot of stations have ethanol in the 91 too. There is only one station that i know of for sure that does not have ethanol in the 91.
I try to get fuel there, but its rather inconvenient. I am concerned about ethanol after having alot of carbed engine problems in the last year or two. Just this last couple of weeks I had two different carbed vehicles with severe flooding problems all within a week or so of each other. Then last summer I had one with that problem too. Its getting old and I feel that ethanol may very well have a part to do with it. |
| Rockester QuadraJet Tuning Tips | GUITAR1989 | Engine | 14 | 06-18-2011 10:28 PM |
| Tuning a quadrajet | Torque454 | Engine | 14 | 02-28-2011 07:06 PM |
| Quadrajet tuning success | Mertz | Engine | 3 | 04-07-2010 03:50 PM |
| Restoring a 41.. | dhaza | Hotrodders' Lounge | 5 | 12-12-2002 05:43 AM |
| Quadrajet tuning Problem????? | cooterks | Engine | 2 | 11-25-2002 12:22 AM |
