Restoring Underside of '62 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2003, 10:47 PM
I am in the process of finishing the underside of my '62 Impala. I want to restore the underside(the bottom of the floorpans and the trunk area) to as close to as original as I can. I have seen other Impalas left in rust red primer, painted the same color as the body, or either painted semi-gloss black. If anyone can tell me what the underside of the '62 Impala looked like when it left the factory, I would appreciate it very much. Thanks for your help, Mike Dwyer
Old 08-04-2003, 08:17 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Hey JTHB...check this site, www.chevytalk.com and scroll down until you get to the '61-'64 Fullsize and ask those guys. I imagine depending on where the car was manufactured depends on the underneath. Same as where they were manufactured depends on the frame that came with the. If you get a chance shoot me a couple of pics as what you got. I'm in the process of getting my '62 all welded up now. I already have the new floor pans in but getting the fender patches in now. I think I am going to use spray in bedliner underneath to insure everything is waterproof. With that you won't have to worry about rock chips tearing it up. But that's me. When I get it back together I am going to drive it so I kind of want it to be bulletproof in the underneath / wheelwell area.
Kevin
Old 01-27-2006, 10:05 AM
Hey Mike...I think I have to agree with Kevin. The underside of mine is all grey, but, my car has lived on gravel for most of its life, so I am not sure. I do know that the firewall, is usually painted the same color as the car. Sometimes I thought that they "dipped" the whole car in the "paint can", but maybe that was on earlier cars? Sorry, not much help. I have some fairly big ideas for my 62. A dual quad 327, air conditioning, power steering(which I already had on the car) power brakes with discs up front, 700R4 tranny, and a 3.73 posi(already had that too) and a coil-over added to the original rear end...So as you see, I have quite a project of my own. Let me know how you guys rides turn out. Tee-Roy
Old 01-27-2006, 09:09 PM
I think this generation of chev had a chassis black frame and the underside of the body was a red oxide primer color. I usually sandblast the frame, coat with black epoxy primer, apply black feathfill G2 on any areas where there is pitting, sand till the pitts are smoothed, apply two more coats of black epoxy, scuff/sand, then apply two-three coats of chassis black. The Frames look top notch when done this way and any chipping down the road won't show up because the coatings are all black in color. The underside of the tub can be blasted then epoxied, primer surfacer, sanded, then coat with a singlestage urethane in the right color to match the original primer color with flattener added to reduce the gloss. It will last forever, Bob
Old 01-27-2006, 09:53 PM
ASE Master but no genius
62 Chevy
My aunt's 62 Impala was white with a greyish appearing underside color. It was a Southern car, so there was no undercoating. Although the northern cars mostly had undercoating (dark grey) which most of the time was done at the dealer before customer delivery. Back to my aunt's car. I don't know what percentage of cars were paint-dipped and/or spray-painted back then, but her Impala had overspray on the areas near the rockers and some on the frame rails and some extending beyond the frame. And no, it hadn't been repainted. Some old-timers will tell you this was very very common. So how original do you want to be.
