Restoring Window rubber Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2011, 07:31 AM
Hi,
My 37 Dodge coupe rear quarter window gaskets are hard from age. Is there way to make them soft and plyable???
Thanks
Sam
Old 02-12-2011, 08:24 AM
I'm told soaking in vinegar will soften them up
Old 02-12-2011, 09:13 AM
hp246's Avatar
Years ago, I restored a Corvette. At the time, there wasn't all the re-pop stuff available. I had to find a way to make the rubber seals around the turn signals, etc pliable. With age, they turned into brittle cardboard. I soaked the gaskets in Armor All in jars for a couple of weeks. It worked and the parts were pliable and usable again.
Never heard of the vinegar trick, but worth a try. Its got to be a lot cheaper than Armor All
Old 02-12-2011, 10:14 AM
That is a neat trick, I am going to be using that. I don't like Amoral on my car, I HATE the stuff. But if that is something that can restore the rubber a little I may just use that soaking trick.
Thanks, Brian
Old 02-12-2011, 10:37 AM
OLNOLAN's Avatar
Silicone Spray Lubricant
I've had good results with silicone spray lubricant. The rubber soaks up the stuff.olnolan
Old 02-12-2011, 11:08 AM
evolvo's Avatar
Heathen
I've had really good luck with these guys. Give them a call and see if they can help.
http://www.restorationspecialties.com/
Old 02-12-2011, 01:59 PM
hp246's Avatar
Thanks, Brian
Yeah, I don't use the stuff at all these days, but back in the mid 70s, I was in a bind, and it was a last resort type of thing.
Old 02-20-2011, 11:54 PM
Last journal entry:
If I recall, armor all was quality back then, but with economics, the mixture changed along the way. Nowadays armor-all does more damage than good. Cracking tires and upholstery... nothing like shiny cracked tires to brighten up your ride.
Old 02-21-2011, 09:09 AM
302 Z28's Avatar
That is really al ArmorAll is.
Vince
Old 02-21-2011, 09:11 AM
302 Z28's Avatar
Thanks, Brian
Brian, I don't know anyone who has anything to do with paint & body work who likes the stuff. I hate it also, and anything with silicone in it.
Vince
Old 02-21-2011, 10:05 AM
Oh hell yes I hate the stuff. But if I can use it to save something like the window gaskets on my Rambler which is made of "unabtainable" I may just carefully use it. I am not painting in my garage so what the heck I can see using it on something that is already painted.
Old 02-21-2011, 08:10 PM
hp246's Avatar
I don't know what it was then or what it is now. It may very well have been silicone. All I know is that I was out of options. The rubber gaskets soaked the stuff up and brought life back to them.
Old 02-21-2011, 11:36 PM
milo's Avatar
point on positive
Brushing rubber with a sand blaster will "freshen" it up if not brittle too.
Old 02-21-2011, 11:40 PM
That makes me go Hmmmmmmmmm, interesting and makes sense.
Restoring ABS Plastic and Rubber Coated Trim starquest Body - Exterior 3 07-16-2009 02:50 PM
Restoring Rear Quarter Window Tracks (Felt/Rubber) - '70 Nova [Pics] Arcuden Body - Exterior 1 02-18-2009 08:27 PM
Rubber gaskets between fender and body farmall_560 Body - Exterior 3 08-31-2008 10:16 AM
little rubber gaskets? PA-Farmer Engine 6 09-18-2007 10:44 AM
using silicone instead of rubber gaskets on OIL pan bullheimer Hotrodding Basics 9 12-30-2005 12:37 PM
