Restrictive or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2012, 09:08 PM
Restrictive or not?
I am running true dual exhaust on a 300 hp crate 360 magnum in a 91 dodge truck the pipe diameter is 2 1/4 and i have an H pipe that is also 2 1/4 and aout a foot long, for mufflers i have 18 inch flo-pro glass packs that have a louvered inside core. But these glass packs did not have any inlets or outlets, we welded our own inlets and outlet on them and they have a 3 inch inside diameter.
I have been told louvered glasspacks are restrictive... But i was thinking since these glasspacks i have dont neck down inside that they'd most likely flow pretty well considering they have a 3 inch inside diameter.
I mean i looked inside these glasspacks before i bought them and they were huge inside 3 inches and they didnt neck down at all becuse they didnt have any inlets or outlets on them we welded on our own wich were 2.5 inches so my exhaust pipe never runs into anything smaller, it only runs into bigger.
So thought i'd ask if this system should give sufficient enough exhaust flow i also have 1 5/8 hedman llong tube hedders. Just wanna make sure i am not choking my engine, there isnt any big bends in my exhaust, for the most part its stright thru exhaust.
Old 10-29-2012, 11:34 PM
techinspector1's Avatar
Wiki Edits: 326
You've built it pretty much like I would have, if that means anything to you.
Old 10-30-2012, 08:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
'Packs having louvers- or anything, actually- that protrudes into the flow path of the exhaust, or cores having irregular, rough openings like those w/saw cuts the length of the core are going to be more restrictive than a muffler having smooth, non protruding openings in the core. As you surmise, the saving grace is the 3" ID- which will compensate for the protruding louvers to a large degree. But they'll still not flow as well as they would w/o louvers; the protrusions still will cause some turbulence.
2-1/4" exhaust pipes are the minimum I'd use. IMO 2-1/2 would be a better size; 3" pipes would be overkill unless you had a lot of length and/or sharp bends or a lot of bends of any degree.
I like the use of a connector pipe between the sides, too. There is an optimum place for the connector, but for vehicles w/a full exhaust system, placement isn't super critical as long as the connector is aft of the collector and before the mufflers. I would choose to put it close to the collectors unless there's a fitment problem. That way there will be a sharing between the two sides that much sooner, which could help reduce backpressure when using a relatively small pipe diameter.
But all things considered, you should be fine w/the set up the way it is. Maybe not optimum, but still OK.
Old 10-30-2012, 07:37 PM
i was thinking the 3 inch inside diameter would make up for any restriction caused by the louvers.. It seems to run good with this set up and it sure does sound good. I wanted to use 2 1/2 inch pipe but it is a 4x4 truck and space for pipe under neath is pretty limited, its a tiht fit with dual 2 1/4 inch pipe already. my h pipe is closer to closer to my glass packs then to the collectors but i figured any balance pipe would be better then none.
Old 10-30-2012, 08:13 PM
Wiki Edits: 326
Exactly right.
Old 11-07-2012, 08:12 PM
would i see more power going to a dual 2 1/2 inch exhaust system from a dual 2 1/4 inch exhaust system? Or would it be a waist of time and money?
Old 11-07-2012, 10:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On a 300 hp engine- unless the system was very long (think school bus) or there are a lot of bends or there are tight bends, going to a 2-1/2" system will not be cost effective looking at it on a dollar-per-hp basis.
If money isn't an object, you could possibly gain a small bit of performance by going to a less restrictive system, but my thoughts are that on a 300-325 hp engine your system is fine as-is.
Old 11-08-2012, 02:12 PM
As long as the louvers point away from the direction of flow and open toward the outside casing they do not obstruct flow. When they point inward and/or against the flow or are simple saw cuts then you get obstruction.
Going from a 2.25 inch pipe to a 3 inch pipe is going to drop flow velocity a lot, the potential problem I see is that the flow may act as if it hit the atmosphere and trigger a negative pressure wave. Nothing wrong with that unless its out of synch with the natural beat of the headers. In the bigger picture this is aways a problem when a termination wave forms whether that's in a terminiation box like Dave Vizard recommends, or at the muffler or the end of the pipe. The goodness or badness of this event all depends on the length of pipe back to the collector and engine RPMs. For a 300 horse 360 this probably isn't anything that should keep you awake nights it is what it is and the engine isn't tuned so close to the optimium edge that wave tuning is going to have any useful effect toward ultimate power.
Basically this system sounds plenty good enough.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
techinspector1 (11-08-2012)
Restrictive Exhaust Question Regal Beagle Engine 13 08-26-2008 07:17 AM
