Resurface of a cylinder head without a milling machine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2012, 03:05 PM
V305's Avatar
On the Border
Have any of you seen/done this before?
Old 06-24-2012, 04:13 PM
poncho62's Avatar
Wiki Edits: 5
I have done that on small engine heads......also, resized a small engine rod the same way......It worked, but they are 10 hp at 3600 rpm, not 300 hp at 5400 rpm
Ontario Rodders
Old 06-24-2012, 06:08 PM
BOBCRMAN@aol.com's Avatar
Your picture instantly goes away on my system..
A large belt sander can be used for cylinder head resurfacing.. I had one years ago with a 14" wide belt on a 30" table. Not real precision but does the job in a pinch.
what to look for when shopping for use milling machine jss Garage - Tools 7 06-07-2011 07:36 PM
cylinder head milling ? 383silverado Engine 2 08-16-2007 12:19 PM
What do you use your milling machine for? dynamicfigure Garage - Tools 13 08-15-2005 08:56 AM
milling machine or lathe Dreadlord Hotrodders' Lounge 3 12-02-2003 03:30 AM
