Resurfacing flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2010, 09:50 AM
I'm putting a project together and got a flywheel with the muncie I bought. I want to get it resurfaced but am not sure where to go. I called my local NAPA store and they were no help. I also checked O'reillys website and there is no O'reilly's with a machine shop within 100 miles of me. I'm in a NW suburb of Chicago, so I thought it would be easy to find someone. Any help? Thanks
Old 12-20-2010, 10:45 AM
SSedan64's Avatar
Most any Machine Shop can resurface it. An Automotive Machine Shop would be best, as they're already setup to do them.
Many Parts Stores have stopped all machining, even Drums/Rotors. Only one that does Drums/Rotors where I live is Oreilly's, none do Flywheels.
Old 12-20-2010, 11:26 AM
King of my Man-cave.
Try to find a shop with a dedicated flywheel grinder. A lathe-mounted job won't do the job properly. Better yet, ask the shop if they use diamond-based grinding stones.
tom
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 10:43 AM
Flywheel Swap / Engine balancing HP52TA Engine 8 04-10-2009 06:18 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 08:20 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 07:44 PM
resurfacing the flywheel 87 350monteSS Transmission - Rearend 8 09-18-2003 01:59 PM
