Retainer ring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2012, 08:41 PM
Retainer ring
Hi yall. I just recently put my 1988-1990 nv3500 gear mesh assemblies back in the rear half of the transmission case and im having a hard time getting the "c" ring retainer for rear main carrier bearing back in place to bolt it place Is it even nessesary to have it Anybody ever work on these transmissions before?
Old 12-24-2012, 04:09 AM
Wiki Edits: 85
If c-ring was not needed, the factory would not have wasted the time machining a groove for it nor have wasted the money buying it.
Old 12-24-2012, 07:45 AM
Its not realy a c ring or snap ring. Its a c shaped piece of metal with three threaded holes. The bolts go through the case and bolt in on the sealed bearings race. Its evermore being a pain to get the thing to line up with the bolt holes in the case.
th350c valve retainer help fast68 Transmission - Rearend 5 07-24-2009 04:00 PM
enough retainer to seal clearance? studlyrocker1234 Engine 3 02-13-2009 03:28 AM
measure valve lift at retainer GMR Engine 9 05-26-2008 08:13 AM
Rocker to retainer clearance MEAN_SBC Engine 4 02-22-2005 08:47 AM
spider retainer? Error404 Engine 9 10-19-2003 03:22 PM
