Retarding a cam in a 383 with tight clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2008, 12:11 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I have a chev 383 that I built a year ago, I installed the cam advanced 4 degrees and now would like to put it to 4 degrees retarded. On assembly I had about .050" clearance between one of the cam lobes and a rod, does anyone know if the clearance gets tighter or looser when the cam is retarded?
Russel
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
SBC valve spring & cam timing 383 jsteve068 Engine 2 07-04-2006 03:40 PM
retarding cam timing fiscus Engine 9 01-09-2004 02:18 AM
383 towing cam cindyandsean Engine 3 10-24-2003 09:43 PM
Cam ?'s Mopar 383 sledge57 Engine 1 10-02-2003 10:16 PM
