Retarding my cam
i just installed my isky 280 mega cam. and i went with the 2 degrees retard for a lil more top end. my power band is 2500 to 6500 rpm,so i figured i might as well use it up high. before i finish the motor should i get a little more retard out of it or standard or advance? ill be running a 3000rpm stall in a pretty light car. cams and timing are def. not my strongest subjects. it will be for the track and the track side of street. lol
i want to hear this, i'll be waiting
ive been wondering about advancing mine |
Renamed the thread from simply "retard". It doesn't do anything for the search features of the board or provide any information about your question.
I see no need to juggle the cam phasing- especially if you don't know where you are starting from. The only way to make an intelligent guess at this is to first degree the cam. Otherwise, just install it straight up. |
I'll say this just to be a stick in the mud... I have always played around with advance/retard, but as Joe Mondello himself once told me... if you have to advance or retard your cam to tune your powerband, you picked the wrong cam. Having said that, I modify his words... if you have to advance or retard more than 2 degrees, you picked the wrong cam. |
thanks guys i actually looked into it alot last night and decided im going to just go straight up no adv, or ret,
i already know that by have it in a 496 will calm it down some, but how much? what would be the overall effects of advancing it and having it in a 496? |
Actually, the opposite will happen, all else being equal. But a lot depends on what your static CR is to begin with.
When you advance a cam, it tends to trap more air because of the earlier closing intake. This will cause the overall cylinder pressure to be greater than if not advanced, so detonation could occur easier. And I believe the cam is ground w/advance already. But besides any of that, your cam is small for that big of an engine. It will have uber torque as-is, I wouldn't change the phasing unless it is to correct any error found when you degree it in. |
| Retarding Accel distributor | 81RocketBonneville | Engine | 1 | 07-27-2010 07:48 PM |
| Retarding a cam in a 383 with tight clearance | fiscus | Engine | 0 | 10-19-2008 12:11 PM |
| cam retarding installation question | KGRIFF | Engine | 4 | 07-29-2007 10:19 PM |
| retarding cam timing | fiscus | Engine | 9 | 01-09-2004 02:18 AM |
| Retarding initial timing. ( try this again ) | KeithB123 | Engine | 17 | 12-09-2003 04:35 PM |
