retorquing of headbolts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2006, 05:03 PM
65Stanger's Avatar
Check the water, check the oil
I had my headgasket replaced and cylinder head remachined, and I was wondering, should I retorque the head bolts again at some point? I was told that I should retorque after engine break in, but it was already too late hehe. Everything's in order now, except for my fuel pump, which I'm replacing today. Should I retorque those bolts at any point?
Old 05-06-2006, 05:22 PM
Wiki Edits: 31
the bolts should streach into torque to when first put on, any more and they loose there strength, so I wouldn't. headder bolts are a diffrent story.
Old 05-06-2006, 05:27 PM
65Stanger's Avatar
ah okay. Thanks! So I shouldn't worry about the headgasket going again?
Old 05-06-2006, 05:44 PM
Wiki Edits: 31
not if they were torqued properly when the head was put back on you should be fine. unless, you used your original head bolts , and u milled the head off, so your bolts would bottom out and only apply a light torque to the head, if u are using the originals, U need to get new 1's of the correct length or use hardened steel washers under each bolt.
