Retorquing intake manifold SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2013, 12:09 PM
Hello guys just a quick question here. I have had my small block chevy in my truck for about a week now and after several heat cycles I need to re torque the intake manifold but I have just a couple of questions. First I know the torque is supposed to be 25ftlbs but I no longer have cast iron heads but aluminum heads and I am afraid to try to put 25ftlbs of torque on the bolts cause don't want to strip them. Would 20 be enough? Also I can't get my torque wrench on all the bolts just the ones up front and the driver side ones in rear. But I can only get a wrench on the 4 center ones and hardly get anything on the passenger side rear bolts? This is the old style slanted intake pattern most common on 87 and earlier small block chevy's. Any of you guys on here able to torque them all with a torque wrench and can I safely torque the bolts to 25 without stripping the threads in the heads.
Thanks guys sorry to bother. First time here with aluminum heads.
Old 04-10-2013, 02:08 PM
Banned
With aluminum heads 25 is to much 20 is better. But i just get them snug.
Old 04-10-2013, 05:09 PM
Well for right now I torqued the bolts I can get too but only 15 pounds and hand tighten with a wrench and a small ratchet but I just snugged them. I am afraid to do it any tighter but one bolt was almost loose before I checked them. Unfortunately I have weaker hand and arm strength from taking chemo and radiation last year cause of my cancer I had and its hard for me to judge my tightening of certain things at times and I just don't want to over do it. I bet I should leave them as tight as they are for now and recheck after a few more heat cycles and if they no longer are getting loose then I should be good. Heck even 25 ftlbs seems a lot for those small bolts.
thanks guys
Eric
Old 04-10-2013, 08:01 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I have aluminum heads and aluminum intake ,I used ARP head studs ,intake bolts and header bolts ,the intake is torqued to 35 lbs exaust to 35 lbs and safety wired heads 90 &80 , The Aluminum Heads are not the problem ,it is the torque yield of the fastners ,use good quality fastners ,Felpro no retorque gaskets,you will not have a problem,on the small block make sure the intake bolts are long enough for aluminum intake since it is thicker at flange ,but not long enough to hit pushrods on 3 cylinders. also you can use a torque wrench if you remove the Carb,
Old 04-11-2013, 07:39 AM
Hello well I am using arp head studs on the heads and I don't re torque them as I use felpro 1003 head gaskets and they don't need re torqued. As far as intake goes I am using grade 8 bolts with lock washers and good fastners on the headers. 35 ftlbs seems a bit much for a small block even factory specs only calls for 30 but if you was able to torque it to that great I just don't want to over do mine and strip out my threads as aluminum strips easier then cast iron and that is what I always ran till now so this is all new to me.
eric
Old 04-11-2013, 08:02 AM
Built Not Bought
eric
Mine is a big block 496 ,but aluminum is the same ,it don't know if it is on a small block or a BBC Checked the factory manual from 1969 chevy with aluminum heads since I am running a 69 tripower alum intake and didn't want to take a chance in warpage ,i torqued mine to specs,i guess after heat set they should be aroung 28-30 have never rechecked them since I use sealer on my intake bolts so oil will not stain 4 center bolts, drop down to about 28-30( if you oil the threads ),but you should use the specs you are comfortable with,i have never had problems with leakage ,warping or stripped threads.,,just a note see what the screw in studs on the guide plates torque to in the aluminum heads, Good luck with your build.
Help Id this old sbc intake manifold B@D Hotrodding Basics 4 09-13-2011 05:38 PM
Best SBC Intake Manifold 1972RedNeck Engine 21 12-29-2010 06:06 PM
sbc intake manifold ? 77novaguy Engine 3 11-09-2008 11:58 AM
GM SBC intake Manifold Retired Hotrodding Basics 12 01-04-2008 07:11 PM
GM SBC intake Manifold Retired Engine 3 01-03-2008 02:47 PM
