retro-fit brakes???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2005, 03:35 PM
Joey Buttafucco's Avatar
howUdoin??
hello peoples...just have a few questions
i have a 64 Impala Wagon that i have already retro fitted the front brakes w/ 1979 corvette spindle and respective 12 inch disks and 4-piston calipers. very cool that these just bolted on..
now i have to deal w/ the rear breaks which are stock drums. i do have a stock rear-end and the current stopping power is crappy!!! i have a master cylinder from a 69 camaro that was originally mated with the 4-piston calipers and rear drums. i cant stop worth beans! my stock 4-wheel drums worked better it seems.
now are there any rear disk applications for my ride that are retro-fit..ie from some other car (i would prefer if there is an "almost bolt-on" application but if mods must be made, i will be able to do so...NEEDING YOUR HELP OF COURSE)...
i am currently doing the entire rear suspension and putting hotchkis everything so i hope to attain a measure of performance for my dear old lead-sled.
thanks
Joey BUttafucco OVAHERE
Old 03-06-2005, 08:06 PM
Grogetter's Avatar
A-body brake info.
Hey! Joey!
Try searching on the Hot Rod and Car Craft magazine web sites. I think your wagon is an A-body and there seems to be a ton of info out there for the A's.
Hope this helps.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
will 72' Firebird front disc brakes Fit? hogggster Suspension - Brakes - Steering 7 02-16-2007 12:21 AM
will 68/69 GTO disc brakes fit 67 camaro 67454 Suspension - Brakes - Steering 3 12-18-2003 08:07 PM
Computer controlled tranny retro fit. Controll your shift points/line pressure. lykan Transmission - Rearend 1 10-16-2003 10:27 PM
Retro fit a ZF 6-speed in a 56 Chevy with a bench seat balweav Transmission - Rearend 1 03-13-2003 04:57 PM
