Retro Help 67 Ford/89GM - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2006, 04:25 PM
Help needed is I installed a 4.3 plus trans into a67 ford econoline. The 1989 astro had a FAL C 187 1 rear end with 205/75 r 15 tires (it should be a 3.42 rearend according to my Info.)1967 Econoline has a WCR-S1 3.00 6KA 783 rearend. I will run tires the outer Dia. same as the 205/75 R15 with the Ford rearend should I regear if so to what ??? I do want to keep performance & fuel economy as it was or as close as possible Thank's Loneranger
Old 02-18-2006, 06:26 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I would run it like it is with the Ford 3.00 rear, see how you like the power before you change rear end ratios, then adjust the speedometer gear to make the speedo read right. Speedo gears are only about $ 10 or less.
If not, Ford makes a 3.25, 3.40, 3.50, 3.56 ratios that could be had at a yard.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
67 bonneville interior champ Interior 1 01-28-2006 07:23 PM
67 camaro rearend 72 Z28 Transmission - Rearend 2 02-09-2004 05:53 PM
Wanted 67 3.8 lt inline overhead cam 6 Captin21 Engine 1 09-22-2003 10:37 AM
