Retrofit snowmobile electric starter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2009, 09:12 AM
cboy's Avatar
Last journal entry: Finished
Anybody ever cobble together an electric starter for pull-start snowmobile?
Yes, I realize this is not exactly a hot rod question...but I'm getting too old (or at least my right arm is) to jerk this thing every time I want to start it.
Always learning...and sharing what I've learned.
Old 10-28-2009, 09:41 AM
Wiki Edits: 31
I would guess it's very possible.. many snowmobiles sold today have electric start and even reverse start ( engine runs backwards for reverse ).. most of the 2 stroke engines really havn't changed with the exception of starting and in most cases there most all liquid cooled now. I'm sure the retrofit is possible with parts for a newer sled
Old 10-28-2009, 11:48 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would start by finding out just what kind of motor that is in that mobile as a lot of the motors did not change that much and it may be possible to just order parts from the electric start version and install them..probably require a flywheel change and the bracket for the starter and of course the starter assenbly as well..
Sam
Old 10-29-2009, 12:38 AM
dinger's Avatar
With all that money you saved by building your last 2 cars yourself, I think you should treat yourself to a new sled. and you can tell your wife I say so! Get you one of them 100 mph out of the box sleds, you'll get across the lake faster.
BTW, where is your car with the new interior? I dang near forgot!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 10-29-2009, 08:34 AM
cboy's Avatar
Unfortunately, I've already spent all that saved money...at least two or three times over.
Regarding the interior, I'm plugging away and have some progress reports in my
journal. At the moment I am a bit bogged down trying to get some decorative aluminum inserts for the flat panels (like the one below) all buffed and polished up real pretty. I made these from some old sheet aluminum a friend had stashed in his garage for many years...and it was very badly scratched and dinged, so I've gotten sidetracked trying to perfect my polishing techniques.
Also, the upholstery learning curve is VERY steep. Much to learn as I move through each step.
Old 10-30-2009, 02:48 PM
Depending on the engine, you may be able to buy a bolt-on electric starter. I know that Northern Tool sells electric starter kits for Techumsa engines:
I'm sure they are available for other engines as well. Note that these are 120V AC starters. The intent is that you start the snowblower in the garage.
Old 10-30-2009, 11:10 PM
cboy's Avatar
That puts a crimp in its usefulness for snowmobiling BUT I might try to get more detail on their setup...just to see the gearing and how they engage the flywheel etc. I might be able to figure something out based on how they do it with 110.
Old 10-31-2009, 05:18 PM
Sorry, I misread your title. Thought is said "snowblower".
Chevy 350 cracked starter mounting hole w pics skiprec Engine 14 11-11-2011 07:47 AM
SBC Starter and flywheel problems WakBordr7387 Engine 18 03-05-2011 03:13 AM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
Electric Seat motors Retrofit. WardellW Interior 4 10-18-2002 01:43 AM
Electric starter for '46 Pontiac pdejesus Transmission - Rearend 2 01-15-2002 07:16 AM
