returnless efi fuel system - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2005, 06:56 PM
william27103's Avatar
anyone ever seen this before, i saw it in a chevy high performance magazine a couple of monts ago, they built a mpfi system and used a returnless fuel system. can you do that? and how would you do it/how does it work?
Old 10-27-2005, 07:39 PM
Siggy_Freud's Avatar
I imagine it would be a fairly low pressure system. Or maybe some sort of pressure shutoff switch at the pump? I dont see any logical reason for this and cant imagine any benefits of running this type of system apart from not having to tap the fuel tank.
Bringing history and technology together.
Old 10-27-2005, 07:50 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Dodge uses a returnless mpfi on the 97-04 Dakotas. I don't know what if any benefits it has, but I have read that people change them to a return type system when making big horsepower changes.
Old 10-27-2005, 08:47 PM
thanks for info
Old 10-27-2005, 11:01 PM
The "return" is kept in the tank on a system like this. The benefit is cooler fuel temps as your not "returning" heated fuel back to the tank from the engine compartment/fuel rails. Don't think fuel heats up on a return style system, should have been on Power Tour this year. Lots of tanks TOO HOT TO TOUCH and pumps taken out due to the near 100 degree temps.
A returnless design is a very nice setup, no matter what pressure you want to run. Lots of ways to skin the cat for reliability on high HP EFI applications, this is just one of them, and cheapest.
Old 10-27-2005, 11:44 PM
how is the return kept in the tank? now i'm confused, and interested, because fuel line and fitting is not cheap
Old 10-28-2005, 12:02 AM
ok, i looked up some info on returnless systems, and the pressure is controlled by a regulator in the tank, or near the tank that doesn't have a vaccum line attached to it to compensate at acceleration and other engine load levels. the fuel rails then have a constant pressure at all times and it is left up to the ecm to adjust the pulse width of the injectors to supply the engine with enought fuel.
my question is now, can my holley commander 950 ecm do this, or will computers that are designed to work with these systems the only ones that will work. and how would i found out if no one here knows. i guess the best bet with that would be call holley...lol
anyways, if i figure out how to do this, i'll keep everyone up to date, i've got plenty of time for experimenting...
thanks guys
Old 10-28-2005, 01:13 AM
aka Duke of URL
I have a tech article on this somewheres in this mess. The excess fuel is collected in a surge tank instead of being returned to the fuel tank. It is immediately available for hi-pressure/draw need. The drawback is that return fuel is used to cool the main tank pump. This would be for strip/serious street duty only.
Old 10-28-2005, 07:52 AM
Technical Support Barry Grant
Returnless fuel system.
These systems are commonly used on low HP newer street cars. Not something that would normally be used on a race application since compensating for g-force, and response time is going to be much harder in a hi horsepower application.
Yes, a complete return style system will heat up the fuel over time. Generally 1 to 3 degrees for every time it cycles. We've come up with a Heat Sink to help eliminate these problems. When doing duty cycle testing running a pump continuously from a 55 gallon drum we could get the tank too hot to touch in about 7 hours (even with the tank being inside a climate controlled environment. The heat sink would take about 90 degrees of temperature out, and stabilize it. The Power Tour proved lots of problems for guys this year, but non more than for the people who live in places like Arizona. They get days well over 100 degrees, and god only knows what under car temps are with the asphalt, and exhaust.
Old 10-28-2005, 08:13 AM
aka Duke of URL
Any chance of posting the description from your catalog or webpage? I would like to see this. Is it anything akin to a fuel cooler?
Old 10-28-2005, 08:21 AM
Here's a link: http://www.barrygrant.com/news/artic...oduct_005.aspx
Old 10-28-2005, 08:38 AM
aka Duke of URL
DAMN! Talk about service...
Old 10-28-2005, 08:49 AM
We try....
Old 10-28-2005, 08:56 AM
thanks guys
Yes the 950 can work fine with a returnless system.
BG, I don't think that heat sink has the btu rejection to have solved the problems we all ran into on PT this year. Many of us literally boiled the fuel in the tank. The solution for some was to coil return fuel line into a cooler prior to returning the gas to the tank.
Old 10-28-2005, 09:05 AM
Stuck one on a car at the Birmingham stop. He had to stop multiple times, and ice down his tank to make it to AL, but was able to run the rest of the tour, and back home without any problems at all.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Plumbing new fuel system william27103 Engine 13 06-24-2005 02:36 PM
fuel system norm671 Engine 4 01-07-2005 10:38 PM
5.7 vortec fuel system jettman Engine 4 11-26-2003 08:50 AM
Fuel Pressure Variance slomotion Engine 2 04-02-2002 02:25 PM
