reuse gas tank or buy new? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2012, 04:59 PM
Wiki Edits: 31
Getting my '51 Chevy ready for the road so I can just drive it. Gas tank didn't leak with 1/2 tank of old fuel in it. I pumped the old fuel out and it's been dry ever since. I'v never had it out so I don't know the condition of the top, but the bottom looks nice.. Have new hose kit and straps to put on it.. Any reason to not use it if it still looks ok? new tanks are $150-200ish so having it boiled out is likely not worth it
Old 03-11-2012, 05:08 PM
JeffB's Avatar
I had one boiled out and pressure tested at a local radiator shop from my '54 that had sat 4 years and old fuel was like varnish,I dropped it off on a Thursday so it could spend the weekend in the tank it looked like new when I picked it up,cost was $60.
Old 03-12-2012, 04:03 PM
Wiki Edits: 31
Boiling tanks around me costs north of $100. thinking about it. Orig has a drain, and new 1's don't. So it might be worth it
Reuse roller lifters or not 1986c10 Engine 13 06-30-2011 04:35 PM
Head Bolts ?? Reuse ? flare1967 Engine 11 09-15-2008 09:25 PM
reuse lifters? awoodman Engine 22 09-05-2007 08:58 PM
reuse lifters? Blackhauk90 Engine 26 08-24-2007 07:43 PM
reuse cam? 84KYSS Engine 1 05-16-2006 05:43 AM
