reuse gaskets or buy new - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2013, 03:28 PM
Banned
Hello..
I'll be installing my cam in my new vortec. thats never run..
if I am carefull and pull oil pan and timing cover. think the gaskets will be fine or..
I'm thinking they should be fine, if they are rubber not paper based gaskets..
discuss
Old 05-15-2013, 04:01 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Geez, knowing the headache associated with front or rear leaks, I wouldn't reuse them, that's just me. I see issues with the corners especially. I've reused trans pan gaskets before without issues, but they're pretty straight forward, flat.
Semper Fi
Old 05-15-2013, 04:54 PM
Banned
I know, but I'm thinking g.m. would by now be using a one piece oil pan gasket. the timing cover is plastic..
Old 05-15-2013, 05:18 PM
generally I say answer your own question as if it were someone else's question. then what would the answer be.
Old 05-15-2013, 05:31 PM
Has it ever had oil put in it. If not I would probably keep the oil pan gasket. IIRC it's a one piece "rubber" gasket with spacers in the bolt holes.
Old 05-15-2013, 06:25 PM
poncho62's Avatar
Wiki Edits: 5
If it was valve cover gaskets or something easy to change, I would say try it.......I would hate to have to pull an engine just to change a leaky oil pan gasket that I cheaped out on.
Old 05-15-2013, 07:31 PM
Banned
I know, right, but penny pinching, is sadly needed..
guess when I open it up. I'll see what they look like and then deside..
Old 05-15-2013, 08:02 PM
Banned
I've reused a used oil pan gasket... Not saying it was smart but it worked.
Old 05-16-2013, 05:55 PM
Good point.
Can I Reuse Head Gaskets? leejoy Engine 13 02-09-2014 08:54 PM
ring reuse cr480r Engine 8 12-02-2012 12:57 AM
reuse gas tank or buy new? matt167 Hotrodding Basics 2 03-12-2012 05:03 PM
Oil leak rear of engine - why? and reuse intake gaskets? sabino56 Engine 12 12-02-2007 02:33 PM
reuse cam? 84KYSS Engine 1 05-16-2006 06:43 AM
