I have a set of hydraulic roller lifters that came from the engine Im rebuilding for 400hp. Theyre the stock GM ones from a 1989 350 2 bolt main. Can I reuse these lifters? Am I correct to think that roller lifters have a significant gain in hp over flat tappet lifters? Either way, im going to go with hydraulic. If I could reuse them, I would, but I just thought id make sure.
if these are hyd.flat tappet lifters and the bottoms dont show any signs of abnormal wear,you can reuse them but ONLY on the same camshaft,and EACH lifter MUST go back onto the same lobe it came off of..If you are changing cams,buy NEW lifters.roller lifters and cams are different and can be moved around.
check that the roller still rolls freely no rough spots check for excessive wear on the lifter body....and if there bad they make great keychains :thumbup: got one polished up and in my pocket now(If you want a photo let me know and I'll get one)
Shane
I agree with you whole heartedly - the cost of lifters as compared to the potential loss of the cam, etc. is pretty small.
But . . . in one of the Dave Vizard books I have around here he mentions that lifters in good condition can be re-used if properly prepped. I believe he basically surfaced them by rubbing them on some sand paper in a figure 8 pattern. I'll look for the book tomorrow and post back.
Again though, I wouldn't . . . it does make me curious as to how many of the guys (if any!) who race and go through lots of rebuilds a year do this though . . .
True, but Pearlman55 commented on flat tappet lifters and their need to remain a matched set. I was replying to his comment and I quoted his comment so that it wouldn't get confused with the original roller lifter topic.
Sorry to get off topic, I guess Pearlman55 branched off and I just followed . . .
Again, sorry for wandering off topic . . . the older I get the more I seem to do that!
You're right, there's lots to learn! I used to wrench on cars quite a bit when I was younger but for the last 20+ years I just haven't had time. A couple years ago I bought an old '74 chevy C-10 and my boys and I have had some fun wrenching on it. My 19 year old son drove it alot when he was 16-18 and now for some reason it's just plain "tired"! So now I'm thinking it needs a rebuild so I've rekindled my old gear head ways.
The weather here has been excellent the last couple weeks - 60s in the evening and 80s during the day . . . prior to that it was high 80s during the night and 100 to 100+ during the day! Just plain nasty!
McCook isn't the end of the world, but you can see it from there! <grin> Actually it's quite a hike west of me and quite a different climate - I'm in southeastern Nebraska, just south of Lincoln. This area is more green rolling hills, out west is more sandhills and stuff.
Well, back to trying to read this entire board in one sitting! <grin>
Will I even have any more power if I keep the old hydraulic roller lifters with a performance cam, versus buy a kit with a new cam, and hydraulic flat tappet lifters? I imagine that a new kit would be more wise, because my engine had 158000 miles on it, although the lifters are fine...
While you need to know exactly what you're doing, flat tappet lifters can be reused under certain circumstances. I've done it many times with no issues. However, many stock lifters are not up to the task of a high performance cam for any number of reasons. In the case of roller lifters, it's a little more forgiving but you still need to make sure they're in good shape and up to the job. Generally, factory Chevy roller lifters are very good pieces. I used my original ones up to about 116K miles with no problems. For about the last 25K miles, they were used with a .525" lift cam and springs with about a 330# open pressure at that lift. In the last series of upgrades, I replaced them with an identical but low mileage factory set, just because I had them sitting around. This is not a real extreme engine but does see 6500 RPM.
Read Jmarks post again, but I will say it for him. Do NOT waste your time on a flat tappet camshaft. You will pay more for a roller cam, but you are getting what you paid for. I have a comp roller cam for sale that has less than 5000 miles on it that works in factory blocks that came with a roller camshaft. There are few oils left that you can get that have zinc and other anti wear additives, without these additives a flat tappet cam will go flat in short order and the powdered metal will kill the rest of the engine and you will be starting over again. If you are interested in the cam I have let me know it`s going for a good price and there is nothing wrong with it, it will give you explosive low end torque as well as better gas mileage.
Is it a problem that I didn't mark the lifters and bores? Because I didnt know to do that when I removed them. Theyre in very nice shape visually and I would take each one apart and clean it thoroughlly and re-oil them and just use them on a nice hydraulic roller cam. What do you guys think?
Okay, so if I use these lifters, can I get away with a cam that costs maybe like $250 or less? What will I want for a cam that goes in my engine? Its a 355 with hyperutectic pistons, stock resized rods, the machined vortec heads from summit for $390 a piece assembled with a max valve lift of .550 in. and valve sizes 1.94 and 1.5, and a 700 cfm carb? I dont know what im using for a tranny yet, but the engine will got in a s10 for the street and strip. I want as much hp and torque as possible, with the car still being drivable on the road.
My compression ratio will be right in the 9.75-10:1 range. I dont have head gaskets yet, so I can be anywhere in that range depending on what gasket I choose. Flat top pistons with 4 valve releifs, -5cc piston head. I plan on building the engine first, then getting a tranny and rear end. No emission testing that I know of..
on this comp link, click on each of the dyno graghs to see the details of the build, roller cams are the bottem section.....you want a cam with atleast 15"HG at 800rpm idle and hp peak around 5500 for a typical "street/strip" build
The roller cam I have is still for sale, less than half the price you`ll pay for a new one. Roller lifters can be reused, so can roller cams. Your looking at over $250 for just the cam itself. And the next lesson for today is, make sure you get the matching springs for the cam you get, you cannot use flat tappet springs on a roller cam. Whatever cam you get, get the springs that cam company recommends. While it can be confusing, whoever your ordering from will pawn flat tappet springs off on you and say "these are good for .600 lift! they`ll work great on the roller cam!" wrong, the fast opening and closing of a roller cam laughs at flat tappet springs and will create coil bind as well as early valve float in which both will result in failure.
Well how do I tell what the springs on those modded vortec heads from summit are meant for? What do most budget builds for around 400hp with a 350 have for lifters? Roller or flat tappet? Either way, im going hydraulic.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
