Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - reuse lifters?
Thread: reuse lifters?
Old 09-03-2007, 10:22 PM
pearlman55's Avatar
pearlman55 pearlman55 is offline
lifters
if these are hyd.flat tappet lifters and the bottoms dont show any signs of abnormal wear,you can reuse them but ONLY on the same camshaft,and EACH lifter MUST go back onto the same lobe it came off of..If you are changing cams,buy NEW lifters.roller lifters and cams are different and can be moved around.
