Reuse pistons (picture) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 08:12 AM
Hello guys, can i reuse this pistons ? (i think i can't, but i dont's lose nothing asking it)
they are JE Forged Pistons, and 1 Melt one of it, Lean i think, with a 383 and weiand 177.
But some of the others come this way:
Old 04-18-2012, 08:19 AM
Banned
You should be fine. I would clean them up, polish them, check them for cracks and skirt wear and run them.
Old 04-18-2012, 08:50 AM
I disagree. those pistons have very short skirts. i see the oil ring going through the piston pin. probablly a short stack on a strorker.
Old 04-18-2012, 08:57 AM
JEP-194887 (piston numbers, 383, 6" rods)
Old 04-18-2012, 04:26 PM
BOBCRMAN@aol.com's Avatar
How deep is the burning into the groove on the top ring? If only outer surface, you could get away with it on a MILD engine. Carbon would build up in that area.
Old 04-18-2012, 05:47 PM
LATECH's Avatar
I would say dont use them. The area above the top ring looks cooked and brittle, and may very well start to crumble away regardless of how the engine is used.
Also note that the Oil control ring has the gap uncomfortably close to the wrist pin relief as mentioned earlier. Of course it was probably moved upon removal, just though it was a valid point though.
If the top area of that piston starts to crumble it could also glow and cause preignition which can Damage the block and heads/valves.
Not worth the gamble in my opinion.
Reuse roller lifters or not 1986c10 Engine 13 06-30-2011 04:35 PM
Reuse brakes lines? V8 Super Beetle Hotrodding Basics 16 03-01-2010 03:18 PM
reuse lifters? awoodman Engine 22 09-05-2007 08:58 PM
reuse lifters? Blackhauk90 Engine 26 08-24-2007 07:43 PM
reuse cam? 84KYSS Engine 1 05-16-2006 05:43 AM
