reused lifter, cam update - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2003, 08:58 AM
DoubleVision's Avatar
Post reused lifter, cam update
Just fired up my car today after swapping cams, I slightly resurfaced my lifters, just added a slight cross hatch pattern. I ran the 20 minute break in, and so far it seems okay, I figured if it was gonna wipe out the cam it would have did it within the first several minutes. I used a Crane PowerMax cam this go round with 210/216 duration. fuel pressure is back to normal at 5 psi instead of 14 the comp cam had, even so they swore it wasn`t the cams fault. TurboS10 asked me to update when I did this, so here it is. I think now I`m gonna hold on to more used hydraulic lifters, it was just too easy. Thanks to all who said how to do it, that was $50 I kept in my pocket.
Old 02-09-2003, 11:47 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
THANKS for the input. Its great when you can do it yourself and work's out good.
Luv the smell of NITRO in the morning.
Old 02-09-2003, 11:50 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
So many people don't give us the final outcomes on thier project's. I apprieciate the effort.
Old 02-09-2003, 12:25 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Right on!
Old 02-09-2003, 02:37 PM
E.T. divided by $ spent= Speed
Post
Why did ya resurace the lifters were they mixed??Ya know everyone says that mixing the lifters will flatten a cam,and I agree that the risk is a little higher but I don't think its really as bad as they say.As long as the lifters are rotateing,its not wereing one constant surface,its spinninmg the lifter each pass.
Eitherway Good Luck
Old 02-09-2003, 02:56 PM
Post
78 Monte, read the other post on rebuilding hydraulic lifters, my post is on there. I didn`t like the idea at first, but after seeing so many do so, and reading about it on this post, I decided to go for it, the most critical time during break in is the first 10 minutes, I ran it over 20 during break in, and I`ve ran it maybe 20 miles today, no problems yet, tomorrow, I`m taking it 120 miles, if I have any problems, yall will be the ones to hear. I haven`t had to go back and adjust the valves, it fires up when I hit the key. and lastly, if I have no problems, it`s $50 I kept in my pocket. If not, so be it, but I think if I was gonna have any problems, I would have had them by now.
