Reusing wheel brg grease. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-28-2006, 10:29 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Please don't try to defend the Wal Mart Service bunch and any of those other oil change outfits. Wal Mart pays $ 7-8 hour and hires mostly people that know nothing about cars except that they are suppose to start when you twist the key.
Getting loose oil filters, loose drain plugs, mis-torqued lug nuts, poor wheel balance, poorly mounted garbage quality tires, incorrect oil grade installed, etc...... is a situation that should be expected from these places.
As far as new car dealerships are concerned... based on my experience,......... good luck pardner.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
what is best wheel bearing grease? NorthStar Suspension - Brakes - Steering 1 05-17-2005 08:07 PM
Wheel bearing grease seal Billy Boy Suspension - Brakes - Steering 3 03-20-2004 08:38 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
