REV Limiter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2005, 05:03 PM
REV Limiter?
Can anybody tell me what a rev limiter does on a ignition box. What is the benfit on a street machine? I am running a bbc with a 671 blower on a street rod Thanks
Old 03-30-2005, 05:13 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Rev limiter
There are some boxes with several rev limiters. The first one is red line limiter. You set it to the max you want your motor to RPM. When it hits that RPM it starts shutting down spark plugs.
The 6AL for example is analog and will shut down the same plugs. The Digital 6 Plus is digital and randomly shuts down different plugs. This is much easier on the engine.
Additional rev limiters can be used on the tranny brake and line lock.
The advantage on a street car is you don't grenade the motor over revving it and at low rpm the ignition box sends up to six sparks to the plug instead of just one.
Old 03-31-2005, 08:42 PM
That way if you miss a shift or break the rear end, the motor won't blow up before you get off the gas.
How to chose nice torq convertor Bandit1980 Transmission - Rearend 13 01-03-2005 06:28 AM
MSD 6AL rev limiter strokercuda Electrical 1 12-01-2004 02:08 PM
wont rev past 6k corona jon Engine 33 05-21-2004 03:12 PM
Rev Limiter and CD ignition setups. Croz Electrical 0 04-01-2004 10:33 PM
Rev limiter CombatWombat Engine 2 03-27-2003 07:50 PM
