-   -   Rev Limiter question (http://www.hotrodders.com/forum/rev-limiter-question-224021.html)
mojapo 09-15-2012 06:45 AM
Either my tach is off or the Pertronix limits revs sooner than I expected. I have the Pertronix III ignition system with built-in rev limiter.
If I set the rev limiter to 6,200, the engine will cutout at around 5,800. 6,700 it cuts out at about 6,400-6,500.
Which is correct, the Tach or the rev limiter?
vinniekq2 09-15-2012 09:24 AM
If your rev limiter is wrong,at least its wrong the correct way.You will need to test your tach against anothet tach and see if they agree or not.
