Rev Limiter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2012, 06:45 AM
Either my tach is off or the Pertronix limits revs sooner than I expected. I have the Pertronix III ignition system with built-in rev limiter.
If I set the rev limiter to 6,200, the engine will cutout at around 5,800. 6,700 it cuts out at about 6,400-6,500.
Which is correct, the Tach or the rev limiter?
Old 09-15-2012, 09:24 AM
vinniekq2's Avatar
If your rev limiter is wrong,at least its wrong the correct way.You will need to test your tach against anothet tach and see if they agree or not.
Rev Limiter? 396chevelle General Rodding Tech 0 03-29-2012 02:32 PM
REV LIMITER? Where is it? mgodfr Engine 7 03-05-2010 02:51 PM
rev limiter tweaked Engine 1 08-12-2007 07:19 PM
REV Limiter? street rodder 1937 Engine 2 03-31-2005 07:42 PM
Rev limiter CombatWombat Engine 2 03-27-2003 06:50 PM
