rever. flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2006, 05:26 AM
Marcel
Last journal entry: Choo-choo town
rever. flow
What is a rever. flow head, and how is it better or worse. thanks
Old 03-06-2006, 08:17 AM
TechnTool's Avatar
OldSchool MotorHead
If you mean"Reverse Flow Head" then you have a head, or more specifically, a car that is designed to rout the coolant to the head first, then to the block. This keeps the aluminum head cooler and is more efficient.
Old 03-06-2006, 08:33 AM
Reverse flow cooling (which will NOT work on just any old engine, typically found on LT-1's) was designed to flow the coolant through the heads first keeping the combustion chamber cooler, thus resulting in increased H.P.
Old 03-06-2006, 10:40 AM
Reverse flow systems pressurize the cylinder heads and bleed off through the block. Coolant gains only 1-2 F as it goes through the block. Reverse flow decreases the temperature of the coolant through the cylinder heads by this amount. The fact that steam rises complicates reverse flow systems and generally makes the 1-2 F reduction in coolant temperature insignificant at best.
http://www.stewartcomponents.com/tec...ech_Tips_6.htm
Poor mans flow bench hotmetal800 Engine 6 02-24-2009 12:46 PM
peak cfm flow or int vs exh %??? ko.17 Engine 14 04-28-2005 01:26 PM
wet vs dry carb flow ratings Litdave Engine 10 09-08-2004 06:15 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
