She's pooched..............
Ontario Rodders |
Like I said, I can start the car and put it in reverse and hit the gas and she will move like new but put it in drive and NOTHING at all. I just find it wierd that the car was shifting so good and all of the sudden nothing. I can't remember all the parts in a trans off hand but if reverse works that means the Band and what is the direct drum works?? What I am geting at is that maybe the forword clutch pack is toasted or something. Just trying to learn and test the knowlege we have here. |
same thing happen to me 700r4
Pull the trans pan and check for broken parts in the bottom of it. My car would'nt go in reverse,1st,2nd or 3rd. It would only move in ODrive. Had the trans pulled and found out it was shot. Blew planetary, clutches completely apart. It was a TCI tranny. I had to get another tranny with some real guts.Check out MAD DOG TRANSMISSIONS.COM
easy guess is the forward clutch pack is bad , broke . Mayb it tore the center out of the drum. Mayb the sprag shelled it's self. The band does nothing for reverse. Weird that it was fine then it quit working? Not at all. People die suddenly every day that were fine an hour before.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I've used that analogy for decades. Have personal experience. I was not being a smart-alec, just making a point.
Tony,, I thought it was really appropiate! And kinda funny too. Reminds me of the auction I used to go to here a few years back. If the guy was trying to sell something that you'd like to know if it worked or not, he always said "Last time it did run, it ran fine!"
Mark |
After reading on the 2004r I am wondering if it was the the high rpm's that did. I been reading that the line pressures get real low with a motor that turns over 6 grand. I am wondering if the fact that I had been smoking the tires and the engine was so high in the rpms that I just completely smokes the clutches when it started to grab at like 6800 or so. That is what the rev limit is set at. I normally shift early to accommodate the wheel spin but that time I didn't.
Crosley when is the band applied? |
2nd gear............
what video or book would you say is probably about the best that shows how to rebuild a 2004r???? I would also like to know what company offers the best complete rebuild kit? And if anybody has any pointers, like throttle valves, servos, shift kits. What will I need to do to get this thing mean enought to handle 450+ horse. I want hard neck snapping shifts. So lets here what yous got??????
| Car Will Not Go Into Reverse?? | HotRodMan | Transmission - Rearend | 15 | 05-22-2007 02:33 PM |
| Reverse idler gear | chumbucket | Transmission - Rearend | 0 | 12-28-2005 05:20 AM |
| Making a reverse shape in sheet metal | John Kelly | Body - Exterior | 4 | 12-16-2005 08:24 PM |
| foward or reverse valve body | 1964chevelle | Transmission - Rearend | 3 | 04-26-2005 08:04 PM |
| 350tranny. no reverse. | Sonkey | Transmission - Rearend | 3 | 02-11-2004 11:31 PM |
