reverse camera help. its a ford. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 01:46 PM
Mr.Fixxit's Avatar
Alright. In my shop I have a 2000 Ford e250 van. V8 automatic. I have the system up and running. Its positive and negative connections with a remote wire. The Guy wants the system to come on when shifted into reverse and it to shut off when its out of reverse. I just need to know what fuse does the reverse lights. Or what wire I can tap into that's on the reverse light switch located on the side of the trans. Can anyone help?
Old 07-09-2012, 04:05 PM
EOD Guy's Avatar
There might be a reverse light relay on the back side of the fuse box, or at least that's where it's at on my '04 F250. I tapped into the out put of that relay when I installed mine.
Old 07-09-2012, 06:35 PM
hi,
black with pink stripe is the color for the reverse lights power wire. maybe the drivers kick panel area, obviously at the reverse light also.
mark
Old 07-09-2012, 06:39 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
That wire- the black w/pink tracer also goes to thingy called a Remote anti-theft personality module.
I'm not kidding.
vicrod
97 ford F-150 no reverse sometimes rtyauch301 Transmission - Rearend 4 02-09-2012 06:21 AM
Ford fast shift from reverse to low tsracer Transmission - Rearend 2 05-22-2010 07:10 PM
Ford C-4 w/ reverse valve body RSM Transmission - Rearend 5 12-17-2009 09:08 PM
No Reverse..ford truck 5 speed transmition MAYNARDTRUCKIN Transmission - Rearend 1 07-17-2007 07:17 PM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
