reverse flow induction SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 05:06 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Interesting oddity...
More info: http://cleverlever99.blogspot.com/
Old 03-27-2006, 07:09 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
That is the coolest thing I have seen in a long time. I wonder what it would sound like and what it would take to do that.
Old 03-27-2006, 07:12 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Probably not be the most efficient running engine out there but it is definitely unique.
Old 03-27-2006, 07:15 PM
I would think that it would burn the intake valves if it were driven very far. But is does make you look.
Scholman
Old 03-28-2006, 01:47 PM
Skylark_77_455's Avatar
Here's a reverse induction nailhead dragster, really cool, check out the blower driven directly by the crankshaft.
Old 03-29-2006, 03:14 AM
Reverse induction flatheads and inlines - Holden and Chev were done here. Check out some 60's f1 engines like BRM v8s and 16s.
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
reverse flow water pump radshell Engine 2 05-23-2005 10:03 AM
What Is Reverse Flow Cooling? STATUTORY GRAPE Engine 9 05-19-2004 10:50 PM
need help quick, reverse cooling flow heads on old block...... Gino Fultano Engine 1 09-10-2003 08:27 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
