reverse flow water pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2005, 07:46 AM
I am running a zoops serpentine system on my zz4 350 and I am wondering if I can run the standard short pump in reverse or do I have to locate a reverse short chevy pump. Can someone tell me what make and model of chevy used a short serpentine pump?
Old 05-23-2005, 08:09 AM
johnsongrass1's Avatar
Race it, Don't rice it!
No. The vanes point in a different direction. Moving water efficiently will suffer.
I believe a pulley change is all that needed.
Old 05-23-2005, 10:03 AM
66Caprice's Avatar
Move It On Over!
You will also need a reverse flow cooling fan if you're not using an electric fan setup.
I think the 1988-1991 corvettes used reverse water pumps but don't quote me on that.
water pump problem rakundig Engine 15 08-10-2007 09:15 AM
Shimming pulleys out to match water pump pulley 406chevelle Engine 8 07-02-2004 09:36 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Stock-type water pump concern... BarbWire Engine 3 07-25-2002 06:09 PM
water pump heater hose conenction.... oldcarguy85 Engine 3 04-07-2002 09:34 AM
