Reverse Headers? Comment to Willys36. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2002, 01:49 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Thumbs up Reverse Headers? Comment to Willys36.
Has anyone heard of reverse headers? Saw a Toyota the other day at a car show with a blown 350 in it and it had a wild header on it. Guy said it was called reverse headers and the company is out of California, but I cant find it on the net. Advance adapyors or something. Anyone heard of this? It had 4 individual tubes about 4 inches long running into one tube which was bigger, then feeding straight back and dropped down into the exhaust. kinda like a stock exhaust that dumps out at the rear. real neat and since it came straight out instead of down, it cleared all the steering shaft, frame and all.
Willys. Got your email. Thanks a lot. Cant email ya back cause my email is acting up, but wanted you to know I got it, Thanks again, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 08-27-2002, 01:54 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Thanks for the message. I was just about to ask you on this thread if you got it!
[ August 27, 2002: Message edited by: willys36@aol.com ]</p>
Old 08-27-2002, 02:02 PM
Wiki Edits: 21
Post
That header sounds like it was designed for convenience (rear outet) rather than performance boost. A properly designed header pipe, with enough length to allow a sound wave to travel up and back will out perform any other configuration you can think of at the engine's tuned power point. No header at all, or 4" primary pipe, is a relatively low performance design other than providing very low backpressure which isn't a serious problem in most exhaust systems in the first place.
Old 08-27-2002, 02:12 PM
Stinkin_V8's Avatar
Suburbanite Member
Post
Can't help you with the header, but I've bought some stuff from Advance Adapters: <a href="http://www.advanceadapters.com/aa.com/headers/jeep.html" target="_blank">http://www.advanceadapters.com/aa.com/headers/jeep.html</a>
The header you describe sounds a lot like the stock V6 Fiero header.
When life hands you lemons, ask for tequila and salt
Old 08-27-2002, 05:08 PM
Post
Advance adaptors is it. I just spelled it wrong.
I think it was for covenience, but would it hurt power. I know that Hemi in the Gremmie is gonna be tight, especially around the frame N steering shaft. Im just thinking ahead. HG
Old 08-27-2002, 06:57 PM
Wiki Edits: 21
Post
No it wouldn't hurt power any more than a stock cast iron header. Just wouldn't give any boost. Why not make a set of headers? Can make a den of snakes that would work and be the talk of your neighborhood!
Old 08-27-2002, 07:02 PM
Post
Willys.
With all your Hemi knowledge and the use of your mechanical skills, Im just gonna insist that you move closer to me or adopt me. Thats it, ive decided, Im coming to live with ya, Me and my car. HG
Old 08-27-2002, 10:38 PM
E.T. divided by $ spent= Speed
Post
Hemmi,Thorley makes all sorts of them funky headers.I think the ones you seen are called 4into1s.They also make Tri-Ys.My oppinion is if Hooker ain't maken um they ain't a good design.But thats just me.
Old 08-28-2002, 05:54 AM
Wiki Edits: 21
Post
Bring Ohio George and Barb Hamilton with ya!
