reverse lights ideas for '65 chevy c10 lwb stepside? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 05:55 PM
Socket Breaker
Last journal entry: My website for my '65 chevy c10 lwb step
a link to a image of the rear of my '65 c10 lwb stepside
I am thinking of mountin' up some round lensed white lights to hang off my rear bumper brackets to be my reverse lights.
I don't want to punch holes in the rear of the fenders to put the original type reverse lights, which were an option in '65 but standard in '66.
So, I thought I'd ask you folks if you have any ideas for lights to use.
just fishin' for some ideas...
Thanks,
-W
Old 04-04-2006, 06:53 PM
stepside454's Avatar
could maybe use the late 70s-early 80s style stepside tail lights with reverse lights built in. like these on my stepside.
Or Ive also seen lights that fit in the roll of the bed sides somewhere...Chevy Duty or LMC maybe.
Name:	resized march 25th rear.jpg
Old 04-04-2006, 07:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
OR, ...
Maybe a Smaller version of this...mounted below or above the bumper..
Doc
Old 04-05-2006, 05:29 AM
Socket Breaker
I was bangin' around the net and came up on these:
http://www.etrailer.com/Merchant2/me...tegory_Code=FL
Code: PL-1038W
Performance Lighting 2-1/2" Round Fog Light Kit
Hmnn.
-W
Old 04-05-2006, 06:49 AM
normal back up lights are only about (?) 20W
the small round 55W lamps you found work so well you can hang them from the frame just barely peaking out....you want flood, not pencil or spot
these in the pic' are $25? Autozone
(footnote for others: tinted "almost flat" rear glass in a fastback= can't see #### at night, till I added the 55W lamps......consider adding them to your car?)
Old 04-05-2006, 03:51 PM
Socket Breaker
red65mustang,
those lights are nice and subtle.
Well, the light in the url above that I posted, they are round and have the mounts that hang down - and only 2 1/2 inches in diameter on the lens... the first ones I've found that hang down and are round and not 4 inches or so.
So, how big exactly are the ones on yer 'stang?
-W
Old 04-06-2006, 07:33 AM
those are ($22 Autozone) 3 1/8" diameter, 55W, a good fit between the frame rail and gas tank decided it....(protection from thrown tire crap)
there are lots of 55W shapes and sizes available, Advance Auto, Pep Boys, Autozone etc
mounted them towards the front of the tank (is why they look so small?) for max "flood" light pattern, did make small "L" brackets so they hang down to "peek" better
had to lay the camera on the ground for the pic, they don't show at all otherwise
clarification to others:....got tinted rear glass....consider adding them to your car
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
ideas for reverse lights? msc66 Transmission - Rearend 9 02-02-2006 08:01 AM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
ideas for reverse lights - '65 chevy truck Woogeroo Electrical 2 12-08-2005 05:48 PM
1984 Chevy C10 1/2 Ton Std. Cab Ideas Ray102386 General Rodding Tech 1 07-23-2003 09:40 PM
