howdy there
well there is a reverse light switch on the column down low under the dash on the auto trans models. is this truck a factory auto trans truck, or has it been converted to auto with an auto trans column ? RPO sticker on the glovebox door shows auto trans from factory ? if so it will show MX1 and MD8 codes there are one or two screws that hold it to the column and you loosen them up and adjust the position of the switch the indicator needle that shows you what range you are in is a whole other adjustment, you simply adjust the cable that runs from the indicator needle to the column shift housing in front of the dash there sounds like someone has swapped the column in the truck or something else and never set these things correctly you kinda need to have a working knowledge on how these work in order to set them. they can be tricky. and in these trucks specifically i have found that often the columns are out of adjustment, more commonly than in other vehicle makes and models, for some unknown reason,. just ask my 91 s-10 pickup outside here, for example. i kind of wonder if maybe your reverse switch isnt jumpered together for some reason(previous column swap related) will the engine crank over in any range other than park and neutral ? youre gonna have to do some exploratory investigation of your column switches to see whats going on. hope you have a digicam to show yours i may be able to take a couple pics of mine or something good luck! Last edited by fast68; 05-19-2009 at 08:59 PM. |
I just checked and it has the MD8 but MX0 code not MX1.... but from the looks of everything it does look like it was factory automatic.....and its actually a 89 GMC S15- body model but i thought from 85-91 s-10 and s-15 models r basically the same?
yeah the truck recieved auto trans from factory then.
mxo or mx1 means there are provisions for auto trans.' md8 is the model of trans., 700r4 hope all goes well under the dash there hehehe good luck! Last edited by fast68; 05-19-2009 at 09:46 PM. |
ok sounds like the safety neutral switch is set right then.
reverse switch will need the adjustment done or the jumper removed, etc. a nd the cable for the selector needle and plate will need adjusted to do that though you will need to remove the cover at the upper "base" of the column. it is held in place by some phillips head screws. it has the small lower heater ducting vent connected to it usually. so you can get to the range slector plate needle cable. and also access the round part of the column that rotates when you shift the trans. this is where the cable connects to the rotating part of the lower column housing, it will be either retained by a phillipos head screw, or simply clipped on tightly. just loosen or unclip it and reposition it on the lower rotating housing of the column so that the cable makes the needle accurate on the pointer plate in each trans range. you should be able to the switches under there without removing anything., other than removing the large flat black below-dash hush panel- that fits around the column/pedals under there. sometimes the floor courtesy lamp is attached to it under there. but not always. most likely this cover hush panel already missing . otherwise no need to remove anything else to access the column andpedal arm-mounted switches under there. a flashlight or shop light will help considerably Last edited by fast68; 05-19-2009 at 10:00 PM. |
lol no its actually on there lol stroke of luck eh?! its actually fairly clean interior to!!! allrighty ill take that cover off and have a look thnx alot eh? Ill let u know what i discover!
oh ok well thatmeans its probably unmolested and probably not jumpered either
the switch may be bad is all. or somehow slipped out of position it looks like it is the white colored switch with the two small wires to it, blue and green colored ones. good luck
| Gear Drive to Timing Cover Clearance | Double_v23 | Engine | 5 | 01-11-2008 11:08 AM |
| Can A Bad Speedo Connection Cause No Reverse And Only 1 Forward Gear | CMROGRL | Transmission - Rearend | 3 | 02-23-2004 06:41 PM |
| 350tranny. no reverse. | Sonkey | Transmission - Rearend | 3 | 02-11-2004 11:31 PM |
| Roller cam/distributor gear information | Jmark | Engine | 0 | 12-29-2003 03:56 PM |
| Back Up Lights - how to choose? | horvath | Body - Exterior | 6 | 03-04-2003 03:20 PM |
