Drag race trannys( 3 speed ) with a reverse pattern valve body can be shifted to 2nd gear after passing the traps and the motor will drop to an idle.
Get the car SLOWED down then place the tranny into first gear OR simply step on the loud (gas) pedal to drive in 2nd gear. Off road trannys usually have engine braking in 2nd gear and you should NOT use them on the drag strip as I describe above .
At the Bonneville Salt Flats, first gear is known as 130 mph. |
